Page: |
Home > Technical Chat > Turbo mini metro new build help. | |||||||
13 Posts Member #: 12129 Member Northern Ireland |
15th May, 2021 at 07:24:48pm
So I am restoring a mg metro 1300 and wish to have an a series turbo in it.
If you don't own one you will never understand.... |
3577 Posts Member #: 655 Post Whore Northern Ireland |
15th May, 2021 at 09:29:46pm
998 and 1275 block are totally different, so no.
Edited by stevieturbo on 15th May, 2021. 9.85 @ 145mph
247 Posts Member #: 11017 Senior Member Shropshire |
16th May, 2021 at 09:19:38am
Sell the 998 engine, you're not going to be using it on this build. |
16th May, 2021 at 12:59:29pm
Thanks for the info. I'll sell the 998 then its all standard.
16th May, 2021 at 09:35:50pm
As already said, a n/a carb can be adapted for boosted use, however that does not make it the same as a turbo SU, which also has additional sealing aspects which would be impractical or impossible for mere mortals to achieve on a n/a carb without some damn good machining abilities
16th May, 2021 at 11:59:55pm
Stevie. I am wanting to know will it work reliably?
17th May, 2021 at 12:00:01am
17th May, 2021 at 12:05:43am
Also I see ur local in n.i. stevie, are you far away. Would love a chat if ur free. I'm new to a series and pretty much using the yellow bible and this forum for my info
17th May, 2021 at 07:32:55pm
Does anyone know if you must use the omega pistons rings with the 73.5 plus +20 15cc dish pistons. Ive got a new set but there are 2 rings missing. And most places only sell a full set.
18th May, 2021 at 09:08:04am
Boost control is entirely up to you, there are many options these days from cheap, to expensive.
20th May, 2021 at 01:07:42am
The omega ones are advertised as less slip or something and they are 120 quid. Which is a lot for rings. I will try dave so thanks for the suggestion.
21st May, 2021 at 05:14:44pm
https://www.youtube.com/watch?v=1c5qsrl-fvw 9.85 @ 145mph
29th May, 2021 at 06:57:55pm
Bit weird someone having a K&N on it...but hey ho. Looks correct apart from that
31st May, 2021 at 05:58:03pm
Turbo carb rebuild procedure is handy but doesn't tell anything about how to convert a hif44 for turbo
55 Posts Member #: 11761 Advanced Member Worcestershire |
1st Jun, 2021 at 08:29:00am
I ran metro turbo parts on an otherwise standard metro 1275engine (i think an LE or something) I still have the engine and the valves are bigger than standard pre A plus and i believe they are also bigger than the turbo version. Mine was back in the 90's when used engines were cheap, i bought the head with the turbo, but never used the turbo head. I ran 30k with about 8 or 9psi, so nothing special, and had no issues. I think the turbo head was mostly to improve long term reliability and reduce the possibility of cracking between valves. The sodium valves were maybe a little bit for the marketing dep't as well.
4th Jun, 2021 at 01:57:09pm
Thanks Jeff just what I wanted to know
4th Jun, 2021 at 03:34:25pm
I'm probably not the best person to recomend parts as I always used cheap standard parts. I have bought adjustable duplex for my 1275 tho (still in box...) and I am contemplating xpin diff. The cost of diff and flywheel/clutch are part of the reason the 1275 is still in bits. As a bit of a recomendation for the diff, when I got my original metro turbo setup, it came from a PYO yard, the selection I made was based on F@#k me the diff on this one is all over the engine bay. The turbo must be a good one!!! To avoid the diff casing on mine being destroyed, I just stuck with skinny tyres. Is that a normal budget fix??? I now have fat tyres and a 998. Edited by Jd24-7 on 4th Jun, 2021. |
Page: |
