Page: |
Home > Help Needed / General Tech Chat > k1200rs conversion - Cam pulley alignment slightly off. | |||||||
4304 Posts Member #: 1321 Post Whore Wiltshire |
8th May, 2021 at 01:33:36pm
Working through the last few teething issues with the k-head before MOT/rolling road. The intake cam pulley tracks nice and straight, whereas the exhaust seems to be running slightly off. Not much, a couple couple of mm, almost like its slightly oval, but may be just not quite sat home properly on the cam.
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
8th May, 2021 at 08:32:49pm
I had the same issue on the exhaust pulley, I stripped deburred and dressed as you suggest and that solved the issue for me.
9th May, 2021 at 09:09:51pm
That’s good, will pull it apart and have a good look. May drop belt tension too.
10th May, 2021 at 09:38:15pm
On 9th May, 2021 minimole23 said:
That’s good, will pull it apart and have a good look. May drop belt tension too. Not up for re-timing it again in a hurry! Shane |
12th May, 2021 at 08:37:31pm
Will certainly do that, I will strip the veneer on this occasion to make sure there’s nothing in there throwing things out. On 7th Oct, 2010 5haneJ said:
12th May, 2021 at 10:16:07pm
It would be a good time to make up some timing reference marks.
Edited by shane on 12th May, 2021. |
169 Posts Member #: 9128 Advanced Member |
14th May, 2023 at 09:29:10pm
Doesn't Jimster make so sort of locking tool for the cams. I sure it was on his website not having any luck getting it to load now though. Edited by DILLIGAF on 14th May, 2023. |
22 Posts Member #: 9839 Member Llanelli ,Wales |
15th May, 2023 at 07:34:47pm
On 14th May, 2023 DILLIGAF said:
Doesn't Jimster make so sort of locking tool for the cams. I sure it was on his website not having any luck getting it to load now though. have a look at this video about half way through he shows it. https://www.youtube.com/watch?v=Q78JA0H-tC4 |
16th May, 2023 at 07:57:44pm
That's the one Bowen |
Page: |
