Page: |
Home > A-Series EFI / Injection > Turbo 998 ( first timer working on minis and first time turbocharging) | |||||||
3 Posts Member #: 12122 Junior Member |
1st Apr, 2021 at 11:09:28am
Hi , I’m new to minis and new to turbochargers , Im only in my teens but the plan originally was to have it as my first car but that has changed as i want to turbo it and make it the best engine possible, I’ve got flat top pistons and I heard that I need dished ones ? Is there a way that I can do this with flat top ones as my dad would go nuts if I sold these as he got them for me for Christmas last year (unless there is someone that is the uk that has brand new dished plus 60 998 pistons and don’t mind swapping) if I used the flat top pistons could I use a decompression plate and the 12g295 head but one that has never been skimmed down ? A lot of people use the 12g940 but I don’t want to pocket my block as nobody local to me can do it and I’ve got flat top pistons so I don’t think it will be possible with the 12g940 head. I was gonna use the kc500 cam but if any experts on here think something else let me know . Also let me know what you think about the whole thing and let me know if there any specific parts that I need for this ultimate 998 turbo engine .
1st Apr, 2021 at 11:10:52am
I was also gonna use speical components fuel injection kit and I was wondering if a 7 port head will work with twin throttle body’s.
3588 Posts Member #: 655 Post Whore Northern Ireland |
1st Apr, 2021 at 08:09:54pm
Doesn't matter what the piston top is designed like as long as you can achieve your desired compression ratio.
2nd Apr, 2021 at 08:50:50am
I have been told if I have got this correct , that if I used the 12g295 head that has never been skimmed down , take 3cc or metal out of the chambers then I will have the correct cr . Correct me if I’m wrong |
2nd Apr, 2021 at 02:34:47pm
On 2nd Apr, 2021 Willpill20 said:
I have been told if I have got this correct , that if I used the 12g295 head that has never been skimmed down , take 3cc or metal out of the chambers then I will have the correct cr . Correct me if I’m wrong I have no idea what your "correct CR" is. Everyones will be different depending on application, goals etc. 9.85 @ 145mph
Page: |
