Page: |
Home > Technical Chat > Running rich | |||||||
13 Posts Member #: 12041 Member |
6th Mar, 2021 at 03:18:56pm
So I’ve finally got my engine up and running, 1310cc 8.1 compression ratio, intercooled, bdd needle, green spring, 20wt oil, part lean off blocked. Now anything more than 30% throttle and goes straight to 8.0afr. Only running 7psi boost as I run it in, and not really reving it past 4K. But any ideas why it’s so rich? It’s perfect at idle and minimal throttle. |
3577 Posts Member #: 655 Post Whore Northern Ireland |
6th Mar, 2021 at 06:48:57pm
wrong needle, wrong dashpot spring, wrong something, blocked air filter
6th Mar, 2021 at 07:18:34pm
May have found a small air leak at the plenum. To be honest it pulls fine when it comes in boost so may be a wrong reading on the wideband? There is also no smoke when it does boost and reads rich.
1648 Posts Member #: 9038 Post Whore Carlisle, Cumbria |
6th Mar, 2021 at 08:24:35pm
On 6th Mar, 2021 TurboTim said:
May have found a small air leak at the plenum. To be honest it pulls fine when it comes in boost so may be a wrong reading on the wideband? There is also no smoke when it does boost and reads rich. Dashpot moves freely. What would be a leaner needle from a BDD to try and work from? Use the minty lamb su site to compare needles. BDD is standard metro turbo needle so I don't see how it can be so rich all the time. The air leak would probably make it run lean rather then rich |
Page: |
