Page: |
Home > Help Needed / General Tech Chat > Suck through weber | |||||||
7 Posts Member #: 11775 Junior Member Australia |
4th Feb, 2021 at 01:42:05am
I have a 45 DCOE, suck through on my turbo (1400cc)
Edited by Indigo on 4th Feb, 2021. 1962 / 66 Mini Monaco under restoration
17 Posts Member #: 12076 Member |
14th Feb, 2021 at 01:31:51am
Block up the bleed back jet. I'd have to check on the pump jet.. |
15th Feb, 2021 at 11:58:45am
Do you have a specific reason for using a Weber ?
7 Posts Member #: 7425 Junior Member |
3rd Nov, 2022 at 10:27:53pm
Hi Indigo, did you fix your problem? I have same issue with a VMAXSCART kit. Been working ok but now same symptoms as you describe. AFR shows lean out when boost stars to rise. AFR goes to 20+ |
3rd Nov, 2022 at 10:27:56pm
5th May, 2023 at 11:46:28pm
On 3rd Nov, 2022 michaelb said:
Hi Indigo, did you fix your problem? I have same issue with a VMAXSCART kit. Been working ok but now same symptoms as you describe. AFR shows lean out when boost stars to rise. AFR goes to 20+ Gave up on the weber - fitted a HIF44,suckthrough. AFR was in the ball park with the first needle I used. Easy Peasy compared to the weber (for me). 1962 / 66 Mini Monaco under restoration
Page: |
