Home > A-Series EFI / Injection > Throttle response: EFI vs SU
NDT
Member #: 11884
I don’t want massive power (yet) but I’m tempted by wet manifold injection for my turbo build.
The one thing I do want is great throttle response (albeit with a little turbo lag).
Can anyone with injection comment on response compared to an SU?
I doubt you'd notice any difference,
tbh injection should be better, as when somthing changes the ecu should react faster than the carb/dizzy.
NDT
Member #: 11884
Thanks and Happy New Year.
I won’t use a dizzy - I’m thinking SU and megajolt vs megasquirt.
If either are properly tuned, you will never notice a difference.
As both Joe and Stevie say, if you do it right you shouldn't see much of a difference.
It all depends on how much you prefer filing SU needles to multiple profiles, playing with different dashpot springs, playing with oil damper viscosity, trying to alter weights and springs inside a distributor...
Or just typing a few numbers into a laptop...
NDT
Member #: 11884
Many years ago I bought an Avonbar high boost needle... so I naively thought I'd just be sticking that in the turbo SU when I rebuild it and not doing mch tuning after that!
After a 20 year restoration I should probably just focus on getting the car on the road and the SU might be the quicker option. Having said that, I'm seriously tempted by injection.
