Page: |
Home > Beginners Tech > What inlet manifold? | |||||||
![]() 52 Posts Member #: 11964 Advanced Member Lindlar |
21st Nov, 2020 at 09:35:42pm
2636 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
21st Nov, 2020 at 10:34:13pm
The Vizard yellow book shows the MG Metro item having a good flow rate above others available.
21st Nov, 2020 at 11:24:50pm
wow, you mean the standard Metro one, not the turbo inlet?
21st Nov, 2020 at 11:31:26pm
Yep, pretty sure from memory the Mg one flows a higher CMF than the turbo one , I'd have to dig out the book to double check.
3590 Posts Member #: 655 Post Whore Northern Ireland |
22nd Nov, 2020 at 12:09:59am
I really wouldnt worry too much. Either will work fine.
![]() 858 Posts Member #: 951 Post Whore Bromsgrove |
22nd Nov, 2020 at 09:41:56am
I use the Std Metro one as nothing else would fit with my large bore Matty exhaust manifold. 'Where does the engine go?' |
22nd Nov, 2020 at 11:11:53am
great infos, many thanks.
Edited by Ralf on 22nd Nov, 2020. |
22nd Nov, 2020 at 11:12:54am
On 22nd Nov, 2020 stevieturbo said:
I really wouldnt worry too much. Either will work fine. Although the turbo one had thicker flanges I believe to better match the exhaust manifold flanges. So if your exhaust manifold has thinner flanges and a normal intake clears it, it may suit better. Or I'm sure I remember something along those lines. Shane |
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
22nd Nov, 2020 at 05:52:52pm
I’ve tested all the above manifolds on my flowbench, the details are on my FB page somewhere.
22nd Nov, 2020 at 07:07:41pm
thanks Phil, I ordered the cast Maniflow.
22nd Nov, 2020 at 08:22:00pm
On 22nd Nov, 2020 Turbo Phil said:
I’ve tested all the above manifolds on my flowbench, the details are on my FB page somewhere. In terms of airflow the standard turbo one is awful. The MG one is good, but the best I’ve tested for a single HIF44 is the cast Maniflow one, though with a bit of work all can be improved upon. Phil. A little turbulence in the standard one probably does no harm though. Ultimately it is in no way a restriction to making power compared to the cylinder heads. But just use whatever fits easiest with whatever is being built. 9.85 @ 145mph
22nd Nov, 2020 at 08:34:42pm
I found it a massive restriction. Fitted to one of my heads it limited airflow compared to when the head was tested on its own.
Edited by Turbo Phil on 22nd Nov, 2020. |
26th Nov, 2020 at 06:33:15pm
I found it a massive restriction. Fitted to one of my heads it limited airflow compared to when the head was tested on its own. The manifold wasn’t just slightly turbulent either, it roared like a hurricane! When flowing with the Maniflow the head flowed its full potential. Phil. How much power difference was there swapping the manifolds at same boost ? Or did boost change with the swap ? 9.85 @ 145mph
Page: |
