Home > For Sale > Smiths Dial, Dashcards, T2 Turbo Plenum, Dump valves and more
Minski
Member #: 10654
Northampton
Hi All
It’s a sad time but I am forced to sell by beloved project due to Change in circumstances. The whole engine and lots of accessories are I all listed on Market place in the following links but details are below. I’m more likely to reply of FB but will check back here as often as I can.
Good luck
https://www.facebook.com/marketplace/item/434478870948430/
https://www.facebook.com/marketplace/item/1345719702434367/
https://www.facebook.com/groups/73234012689...48675011924950/
https://www.facebook.com/marketplace/item/2702677400048061/
Unused Smiths oil pressure and water temperature gauge
£90
Short Turbo Engine - ~1000 miles since build
1293cc +20 Omega 10cc cast pistons (20thou deck height)
Balanced A+ conrods with ARP rod bolts
Standard grind CAM6581 turbo crank. Polished, measured and balanced (by EDA) prior to installation
Centre Main Strap with Finnings CAT HT bolts and hardened washers.
All new bearings including cam bearings
Lightened cam followers
Avonbar Phase 2 Cam
Swiftune adjustable timing gear
"Genuine" Powerflow Turbo oil pump bought from Avonbar
Proper cast impellor water pump.
Flat breather timing cover.
All oil gallery plugs pulled and replaced with hex plugs
All core plugs replaced
Block was tank cleaned prior to machine work being carried out (by drakes in bradford)
SOLD
Modified Turbo Head
Orignally started life as a Minispares MSE3 head but was reworked by BENROSS to have 28cc chambers and significant additional porting work.
It also sports 30mm exhaust valves (hardened seats suitable for unleaded), double springs, inner spring locators etc.
Powered the worlds fastest metro van (sic) to a 13.9 up the strip and 175bhp on 17psi of boost on the rollers.
Done approx 2000miles since BENROSS reworked and reconditioned the head with new valves, guides, springs etc and the additional porting.
SOLD
Rebuilt SC/CR Gearbox with 3.2 FD (no differential) 1k use
Minispares Clubman Gearset
All new bearings (All genuine)
Central Oil Pickup
Blasted gearbox casing
Blasted turbo transfer casing with new bearing and race installed
helical transfer gears (including primary & idler)
SOLD
Brand New (but fitted so will have to remove) X pin diff wit new output shafts and diff roller
SOLD
New (currently fitted but unused) Race spec clutch 4 plate paddle plate (c-aht599), competition pre verto lightened pressure plate (c-aht230), steel flywheel (c-aeg421) includes all the housing
£250 collected
Brand New Maniflow Turbo Exhaust 2” with brackets
SOLD
MPI fuel tank
SOLD
Brand New centre binnacle and chrome surround
SOLD
Brand New Dash card oval no vents
£15 collected
Brand new Tacho housing chrome 80mm
£15 collected
Brand new Smiths Tacho Rev counter 80mm
SOLD
Bailey Dump valve
£40
Brand new DSN billet alloy thermostat housing with M10 Tapping in front
£40
Brand new DSN billet alloy adjustable engine steady
SOLD
Brand new DSN turbo oil drain
SOLD
Mini Turbo Plenum and dump valve
£120
Unused Matty Manifold
SOLD
Matty Downpipe
SOLD
Garrett T25 turbo with 0.49 A/R turbine housing and a 50 trim compressor wheel, built with 360 thrust bearing- including actuator with welded bracket by Matty
£350
Competition steady bar bush kit
SOLD
Brand new Gaz standard height front and rear shocks
SOLD
Brand new Hi-Lo Front and rear with Rear unit rods and plugs
SOLD
Brand New thermatic fan
SOLD
Recently rebuilt HIF44 carb using the full rebuild kit
SOLD
Thanks 😊
Edited by Minski on 11th Dec, 2020.
Minski
Member #: 10654
Northampton
Have updated
Minski
Member #: 10654
Northampton
Have updated
Minski
Member #: 10654
Northampton
Updated. Not a lot now left
Yoda74
Member #: 11728
Uden, Holland
PM’d you
