Home > General Chat > metro turbo engine on 45 weber
mk1 turbo
Member #: 12027
my mates just bought a metro turbo engine with 42,000 miles on it , hes wanting to run it on a weber 45 ,however i think hel need to alter the compression ratio to suit , i may add he only has the full block, head and gearbox but no turbo or plenum ,hence the carb route, any thoughts on this thanks,
Edited by mk1 turbo on 9th Oct, 2020.
No benefit to running a standard 63hp engine on a Weber, probably happier on an su. They should run well in NA tune at 9.4 standard turbo compression.
mk1 turbo
Member #: 12027
thanks for the reply , im not much help to him as im more into car bodywork thanks for the info, i just thought the cr would be too different
He's just adding complication that isnt needed.
Turbo SU works, is easy enough to tune and easier to fit.
Although why bother with a turbo engine...and no turbo ? Seems pointless...and even less worth doing a DCOE.
Edited by stevieturbo on 9th Oct, 2020.
mk1 turbo
Member #: 12027
only reason hes using the turbo engine is he got it for peanuts as the guy just wanted rid of it out his garage as he was moving away and couldnt be arsed shifting it
Mr Joshua
Member #: 1954
Luton Bedfordshire
To run a 45 it would need to be suck through not blow through
Own the day
