Page: |
Home > General Chat > Inlet manifold sealing | |||||||
29 Posts Member #: 12076 Member |
30th Sep, 2020 at 11:08:03pm
What have people done re sealing the manifold to head? I'm thinking boost and simple gaskets might not be ideal - should I cut and fit an o ring, either to the head or manifold flange. Trying not to overthink this but it will be a bespoke manifold and plenum, designed to fit in the space available.
2636 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
1st Oct, 2020 at 07:45:12pm
On my first k100 inlet I took a piece of ally flat bar and bored the holes in for the inlet ports, I then bored a recess for an O ring. The main holes then had tubes for the inlet runners slipped through and welded.
2nd Oct, 2020 at 04:35:19pm
Yes, pretty much what I was thinking. Luckily I have an ac tig...
2nd Oct, 2020 at 06:48:09pm
Bk450 holds up well. Just used a transfer punch to mark the holes for the studs then a wad cutter to cut them.
Edited by shane on 2nd Oct, 2020. |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
3rd Oct, 2020 at 06:16:00pm
Never had a problem just using silicone
Page: |
