| Home > A-Series EFI / Injection > AFR Distribution with TBI setup | |||||||
17 Posts Member #: 11040 Member Portsmouth (South East) |
22nd Sep, 2020 at 09:26:50pm
Hi All,
![]() 4633 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
22nd Sep, 2020 at 10:42:32pm
I’m not sure if anyone has fitted dual wideband sensors with a wet manifold setup, or a least not anybody that’s shared the results on here.
23rd Sep, 2020 at 12:07:53pm
Cheers Phil. I figured there was a reason I couldn't find anything!
Edited by gcos93 on 23rd Sep, 2020. |
23rd Sep, 2020 at 02:51:13pm
As Phil says, no genuine data on this forum (there may be elsewhere but I doubt it).
23rd Sep, 2020 at 05:04:41pm
Thanks Rod!
On 23rd Sep, 2020 Rod S said:
Otherwise, on a throttle body/wet manifold, just put a single wideband after the turbo and use other signs - spark plug colours or holes in your pistons, to gauge the offset..... Hmmm well yes. Holes in pistons indeed... best avoided!
23rd Sep, 2020 at 05:53:42pm
One thing you will need to do is to have 4 injection pulses per engine cycle. That's the only way you can have an AFR distribution that's close to correct.
23rd Sep, 2020 at 06:15:44pm
Thanks Jean :)
23rd Sep, 2020 at 06:57:53pm
The MS3 also doesn't have a siamese code option. You need to use sequential injection and single pulse setup (not an MS3 option but the way to wire injectors and how you tune the injection timing); you also lose 2 injector channels. So if the Speeduino has sequential injection, you have the same option. The only ECU that has a complete siamese-port option is the MS2. |
23rd Sep, 2020 at 07:20:03pm
Ah ok, interesting. I'll do some more digging around here on the siamese code to better understand what I might be missing out on. Speeduino does seem to support sequential up to four cylinders.
23rd Sep, 2020 at 07:49:17pm
Nothing preventing you from using the fuel trim tables but you might also need to tune injection timing to get a perfect AFR distribution. But if you start tuning the injection timing, you might be able to simply use that with the main VE table to get the same result which would be much less work than playing with timing, VE and trim.
24th Sep, 2020 at 06:26:53am
If you go for a rear mounted (ie, more conventional) turbo setup the sample chambers can be quite unobtrusive.
24th Sep, 2020 at 09:26:38am
The problem with TBI with sequential, timed injection as I see it is that the injectors are sitting at the end of a manifold and port that is greater volume than the cylinder. So, theoretically you need to start injecting before the cylinder starts filling. Even then some or all of the fuel will be left sitting in the port.
Edited by Paul S on 24th Sep, 2020. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
257 Posts Member #: 11017 Senior Member Shropshire |
24th Sep, 2020 at 09:42:36am
On 23rd Sep, 2020 gcos93 said:
Cheers Phil. I figured there was a reason I couldn't find anything! Has anyone even run TBI with >15psi boost before? I saw a post from wil_h saying that he ran 12psi with the SC TBI kit but I couldn't find anything else. I could start by doing some trials with TBI on my brother's NA mini using twin widebands. Not sure how representative it will be for a turbo setup but I'm not keen to fit dual widebands to my turbo due to needing sample chambers. I suppose data from an NA motor would be better than no data at all... Grant I run 18psi on an SC set up with 2x 630cc injectors. I regularly check the sparks and boroscope the cylinders for any potential signs of det, I also used a phormula KS3 as a sanity checker. WOT AFRs are around 11.8-12, taking into account that the WB is at the bottom of the downpipe. |
24th Sep, 2020 at 12:57:00pm
Thanks everyone for the helpful responses!
On 24th Sep, 2020 Paul S said:
The problem with TBI with sequential, timed injection as I see it is that the injectors are sitting at the end of a manifold and port that is greater volume than the cylinder. So, theoretically you need to start injecting before the cylinder starts filling. Even then some or all of the fuel will be left sitting in the port. This is an interesting point. I'll do some thinking on this as it does seem possible to get it "working" to some extent. I suppose as the duty increases, the situation becomes closer to that of a carb where there is a more continuous fuel distribution in the manifold? The effect you describe must have a bigger impact at low duty I would think? I guess there must still be a point where the airflow "switches" from one manifold branch to the other and I guess that point in time would be close to the optimum injection start point...? Steve: On 24th Sep, 2020 Steve220 said:
I run 18psi on an SC set up with 2x 630cc injectors. I regularly check the sparks and boroscope the cylinders for any potential signs of det, I also used a phormula KS3 as a sanity checker. WOT AFRs are around 11.8-12, taking into account that the WB is at the bottom of the downpipe. Very interesting. Thank you for this. So it might be possible to achieve what I want with SPI... Everyone: So currently, I'm thinking that I'll aim to bodge together a quick and dirty SPI setup to test with dual widebands on an NA motor. Just to satisfy the collective craving for knowledge! Depending on the results I may then transfer to the turbo or have a rethink. |
24th Sep, 2020 at 08:13:02pm
Thanks for confirming that you were talking about port injection when you mentioned sequential. That's what I read in your previous message and what I considered when I replied. I also don't see the point in using timed injection when using a TBI setup and that's not what I was advocating, if that was not obvious. |
24th Sep, 2020 at 08:35:06pm
Ah sorry Jean. Were you responding to this comment from my previous post?
On 24th Sep, 2020 gcos93 said:
Just to clarify: If I go TBI, I'm not intending to use the siamese code. I was just thinking that if I start off with an MS2 then I have the possibility to upgrade to port injection at a later date depending on my success with TBI. If so, that comment was addressed to Rod to cover this comment: On 24th Sep, 2020 Rod S said:
Re. the MS2 siamese code it was really only intended for port injection with timed pulses to co-incide with the individual inlet valve openings so the injectors have to be as close to the valves as possible. I might be wrong but I don't think it would work very well with a TBI setup because (a) the injectors would be a lot further away and (b) they wouldn't be physically associated with only one runner each. Sorry for the confusion... there were so many posts I figured I'd try to reply to all of them in one go but I didn't do a good enough job of breaking them up. Thanks for all of your input
24th Sep, 2020 at 09:55:09pm
No I was responding to Rod and Paul who both mentioned that TBI and sequential don't mix well which neither you nor I were proposing. I just wanted to make that clear to both and that I agree with them. Edited by jbelanger on 24th Sep, 2020. |
25th Sep, 2020 at 12:14:41pm
Rod: Your sample chambers look very tidy! What sort of fittings have you used to connect the pipes to the sample chambers & manifold? Some sort of compression fittings? Flared pipes? Stainless steel compression fittings. 6mm OD stainless tube for the compression bit and either 1/8 NPST or BSPT for the threaded bit (can't remember which, I've got some of both and both taps). The important bit is the "T", tapered thread so no sealant needed. The 6mm tube is either 0.5mm wall or 1.0mm wall (again, can't remember, I bought a bit of both and did toy with the idea of making the longer tube the larger diameter so the gas flow would be quicker and get there at the same time as the shorter tube but decided against it because the centre sample is hotter anyway - the small green wires you see in the photo are thermocouples, Paul, Graham and myself have used them at various times to check various things hence why we know there is little or no correlation between EGT and AFR). The tube out of the chambers down to the downpipe just below the turbo flange is 16mm bore (can't remember the OD, but it's either 1.6 or 2mm wall thickness just for rigidity whilst still being able to bend it around a former without kinking). The 14point7 controllers I use, in conjunction with Jean's T-IOX code, read the LSU temperatures and they are rock steady at 750C+/-1 whatever the engine load and the AFRs respond very quickly to changes so I think the tube size ratio must be pretty much spot on. and Jean, sorry about the confusion, I didn't read carefully enough, I just saw TBI in some parts of the thread and MS-2 siamese in other bits. Schrödinger's cat - so which one am I ??? |
