Page: |
Home > General Chat > Metro challenge info and specs? | |||||||
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
12th Sep, 2020 at 05:13:32pm
Nothing gets past Dave lol NOTHING GETS PAST ME!! ![]() 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
14th Sep, 2020 at 09:17:33am
Look the regs up online, that will tell you what it "should" be. If something is worth doing, it's worth doing half of. |
14th Sep, 2020 at 09:16:44pm
5.7a.1.2 MG Metro Turbo It is permitted to modify the cylinder head combustion chamber, inlet and exhaust ports but standard inlet manifold locating rings (nominal outer diameter 34mm) must be retained. The maximum permitted compression ratio is 8.65:1. Modifications to the cylinder head and block to regulate coolant flow are permitted. The maximum permissible piston diameter is standard production plus 0.020”. A Rover CAM 6648 camshaft is mandatory. Maximum valve lift is 10.92mm (0.430") with a valve clearance of 0.4mm (0.016”). Rocker assembly is unrestricted.
14th Sep, 2020 at 09:20:41pm
other stuff here
15th Sep, 2020 at 09:04:56am
More mods allowed than I thought!
On 14th Sep, 2020 Joe C said:
5.7a.1.2 MG Metro Turbo It is permitted to modify the cylinder head combustion chamber, inlet and exhaust ports but standard inlet manifold locating rings (nominal outer diameter 34mm) must be retained. The maximum permitted compression ratio is 8.65:1. Modifications to the cylinder head and block to regulate coolant flow are permitted. The maximum permissible piston diameter is standard production plus 0.020”. A Rover CAM 6648 camshaft is mandatory. Maximum valve lift is 10.92mm (0.430") with a valve clearance of 0.4mm (0.016”). Rocker assembly is unrestricted. Page 14Standard production inlet and exhaust valves must remain with the following diameters: Inlet 35.58mm Exhaust 29.45mm Crankshaft STR 931 or standard production tuftrided (STR 0040) are also permitted. The crankshaft may be lightened. It is permitted to lighten and/or balance the connecting rods. It is permitted to machine a small groove 1mm wide and 0.5mm deep on both sides of the con-rod above the top bearing and/or modify the main oil gallery to allow a jet of oil to be sprayed into the piston crown to aid cooling. The crankshaft and connecting rods can be chemically or heat-treated. If something is worth doing, it's worth doing half of. |
16th Sep, 2020 at 09:55:58pm
So info is slowly being received..
Page: |
