Page: |
Home > Technical Chat > Sodium-filled exhaust valves - worth it? | |||||||
25 Posts Member #: 11884 Member |
4th Sep, 2020 at 04:41:23pm
I have a Metro Turbo head and a couple of MG heads.
852 Posts Member #: 951 Post Whore Bromsgrove |
5th Sep, 2020 at 08:48:00am
For me, get rid of the sodium cooled valves: larger guides so more port interference, they're friction welded,always a concern. I have run stainless valves for over 10 years at around 200 bhp without problem. 'Where does the engine go?' |
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
5th Sep, 2020 at 11:11:45am
The Valves in the MG head will have a part number etched into them Tam 1062 comes to mind can't recall the other number, you can check the size from that. Keep the inlets and fit stainless exhaust valves. You don't want to be fitting anything bigger as you run the risk of cracking the head between the valve seats. Own the day
3577 Posts Member #: 655 Post Whore Northern Ireland |
5th Sep, 2020 at 09:40:08pm
For turbo, I'd want either sodium filled or inconel.
4622 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
5th Sep, 2020 at 09:54:41pm
All aftermarket modified A-series turbo heads run the stainless one piece race valves, they do need to be run in bronze guides though.
6th Sep, 2020 at 09:15:49pm
On 5th Sep, 2020 Turbo Phil said:
All aftermarket modified A-series turbo heads run the stainless one piece race valves, they do need to be run in bronze guides though. The original sodium filled exhaust valves weren’t available for a long time, but recently Minispares have had stock. For a standard or low boost engine the sodium valves will be fine. For high output I’d look at the stainless ones. Phil. How many aftermarket heads are there ? Most modify OEM heads. I retained standard exhaust valves, although for a short time did run the larger 32mm I think it was that one person offered at the time....however, that in itself turned into a nightmare story on the 2nd head I ran due to the need to offset the valve.. 9.85 @ 145mph
6th Sep, 2020 at 09:29:35pm
When I said aftermarket I meant all modded 5 port heads, rather than alloy castings etc
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
7th Sep, 2020 at 08:09:01am
20000 miles on a Turbophil head and up to 17psi and never had a problem (and it was used on track, hillclimbs,drag strip etc. |
8th Sep, 2020 at 05:49:14pm
On 7th Sep, 2020 tadge44 said:
20000 miles on a Turbophil head and up to 17psi and never had a problem (and it was used on track, hillclimbs,drag strip etc. Back when I ran mine, I probably did around 60k on sodium filled, as much as 25psi at times with a terrible setup ( no widebands etc in those days, and a daily driver ) I broke lots of things....valves weren't one of them lol. 9.85 @ 145mph
Page: |
