Home > Non-Mini Projects > Help needed
Jd24-7
Member #: 11761
Worcestershire
Oops!
I have put some shelves up in my new garage (I really hate putting up shelves) but this morning I discover this disaster!! See pic.
What do i do? Should I refit the shelf , or trim the top edge of the book?
monsterob
Member #: 11029
Crewe
Put it in on an angle
Outside the box
evad1980
Member #: 10165
Stansted, Essex
Mr Vizard wouldn’t approve of chopping the book (plus it’d be dog rough) 😂😂
Surely moving house is the only sensible option here?
Rammie2000
Member #: 10190
belgium
Bit of the top bit of the bottem. Who needs titles and pages. That is soooo 90s.
Jd24-7
Member #: 11761
Worcestershire
Good call. Anyone selling one of those houses with a long winding drive (tarmac) and lots of outbuildings, and maybe a barn , around 200k ??
Mr Joshua
Member #: 1954
Luton Bedfordshire
You had one job, one job!
Own the day
route out a rebate in the top and the bottom of the shelf for it to slide in. It can’t fall over then either!
Jd24-7
Member #: 11761
Worcestershire
[quote=minimole23,23rd Aug, 2020]route out a rebate in the top and the bottom of the shelf for it to slide in. It can’t fall over then either![/quote
That is absolutely the best option. It will undoubtedly be the most time consuming solution, but needs to be done, just because!!
Pic to follow ]
