Page: |
Home > 998cc > Ever seen a white small bore headgasket? | |||||||
1750 Posts Member #: 10190 Post Whore belgium |
21st Aug, 2020 at 09:35:53pm
Opened up a gasket set from minispares today and a white headgasket came out. Never seen this before.
3588 Posts Member #: 655 Post Whore Northern Ireland |
22nd Aug, 2020 at 10:02:15am
What make is it ? Is there 2 gaskets in the bag ?
22nd Aug, 2020 at 10:56:44am
No idea of make. It's just one. Lays on top of a copper one. Came from minispares. In a gasket box. you can do anything if you set your mind to it...
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
22nd Aug, 2020 at 08:39:44pm
I had one I used when mocking up my K head, can't remember where it came from tho?
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
23rd Aug, 2020 at 11:05:37am
Not seen one of those in a long time. Back in the day when the copper gaskets were hard to get you would have to fit one of those. If the engine is standard compression you will be okay but if your running high compression you will blow it for sure. Own the day
23rd Aug, 2020 at 09:05:13pm
So worth nothing to me then.
24th Aug, 2020 at 05:55:58am
Just checked my order.... So that is what they gave me for the 998 performance gasket.
24th Aug, 2020 at 02:20:30pm
On 24th Aug, 2020 Rammie2000 said:
Just checked my order.... So that is what they gave me for the 998 performance gasket. http://www.minispares.com/product/Classic/C-AEA647.aspx Sigh. Lesson learned. Are you sure? We haven't sold the 647 gasket in 5 years, currently testing new samples. |
25th Aug, 2020 at 06:03:18pm
Just checked my order.... So that is what they gave me for the 998 performance gasket. http://www.minispares.com/product/Classic/C-AEA647.aspx Sigh. Lesson learned. Are you sure? We haven't sold the 647 gasket in 5 years, currently testing new samples. you can do anything if you set your mind to it...
26th Aug, 2020 at 09:30:58am
Send me the invoice number please and I'll check for you. |
26th Aug, 2020 at 06:46:57pm
ill pm you you can do anything if you set your mind to it...
Page: |
