As per title,
2KW SHORT WAVE INFRARED PAINT DRYER.
As I have swapped from 2k to 2k non Iso, this is no longer of uses to me, and with space in the garage at a premium I would rather sell it on than store it in the loft for the next 25 years.
I would estimate it has probably run in total for about 5 hrs.
When not in use it was stored under a sheet to keep dust off.
There is a little over spray on the stand, plus some paint left over from dirty mits moving it about, other than cosmetics, it is in prefect working order.
This is the product and supplier:
https://jackram.co.uk/index.php?main_page=p...products_id=296
and the description:
HUNDREDS SOLD RELIABLE UK SUPPLIER
NEW IMPROVED DESIGN - DIGITAL TIMER + PULSE CONTROL.
Also allows you to increase/ decrease the heat from the bulbs.
Competitors pictures look similar but have basic wind up timers.
2 X 1050 WATT SHORT WAVE QUARTZ HALOGEN INFRARED TUBE
PULSE CONTROL FOR PRE HEAT OF PANEL.
LAMPS CAN BE SET VERTICALLY AS WELL AS HORIZONTALLY.
MAX POWER = 2000 WATT
RANGE OF TIME = 2 X 60 MINUTES.
BAKING AREA = 0.6 X 0.8 M.
OPTIMAL BAKING TIME = 15 - 30 MINUTES
BAKING TEMPERATURE = 50 - 100 C.
INPUT VOLTAGE = 230V 50 Hz.
INPUT CURRENT = 9.1 Amp.
HEIGHT OF POST FROM FLOOR LEVEL = 165 CM
EACH LAMP FULLY ADJUSTABLE WITH BRAKES ALSO UNIT ADJUSTABLE IN HEIGHT
4 SWIVEL WHEELS (2 WITH BRAKE).
SPARE PARTS KEPT IN STOCK
I’d like £150 for it.
Collection preferred from Hungerford, Berkshire, but I can arrange courier at extra cost if required.
’77 Clubman build thread
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=618189
Siamese 5 port EFI testing
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=611675
