Home > Wanted > Wanted brackets Etc
Harper
Member #: 12038
Hi all
Based in the West Midlands, I need a bottom rad bracket, a Speedo drive cable ( two clock type1984) alternator and brackets for that too.
Thanks Adam
Edited by Harper on 20th Jun, 2020.
shane
Member #: 1246
Lowestoft, Suffolk.
Welcome to the forum.
I have an alternator spare with bracket, and possibly a bottom rad bracket.
Shane
Edited by shane on 20th Jun, 2020.
Harper
Member #: 12038
Thanks,
Cool, how much would you want for them.
Harper
Member #: 12038
Got a bit button happy
shane
Member #: 1246
Lowestoft, Suffolk.
I need to have a rummage in the loft first to confirm I have the radiator bracket, are you after the small bracket that mounts the rad cowl to the engine mount bracket or the entire mount/bracket assembly?
Shane
Harper
Member #: 12038
The small one, I have the mount
monsterob
Member #: 11029
Crewe
If you don't find one I'm sure I've got one
Outside the box
shane
Member #: 1246
Lowestoft, Suffolk.
I shall check tomorrow and confirm.
I'm also assuming that you require a standard Lucas alternator not the smaller Nippon Denso.
Shane
Harper
Member #: 12038
I was going to just use the stock alternator to get me going.
shane
Member #: 1246
Lowestoft, Suffolk.
I can confirm I have;
Standard alternator
Alternator bracket
lower radiator mount.
PM Sent
Shane
