Page: |
Home > Technical Chat > RTS ... Sorry | |||||||
![]() 8215 Posts Member #: 90 Post Whore Somewhere around Swindon |
23rd May, 2020 at 03:34:40pm
I know there has been a fair few threads on the RTS over the years but some of the better ones are nearly 10 years old and a lot changes in 10 years.
264 Posts Member #: 11029 Senior Member Crewe |
23rd May, 2020 at 04:55:02pm
I just built one onto a med lightweight flywheel used dome head bolts and nylocks passed through from the back of the assembly.
Outside the box |
24th May, 2020 at 12:23:21am
My Minispares backplate needed a 3/4x1/2x3/16 lump of steel welded into one of the pockets to get it balanced.
25th May, 2020 at 07:26:02pm
Use the ap pressure plates ( the ones with the ring on) as they are much easier to deal with as they have a puurely conical spring rather than one with 2 wangles so they sit together better.
![]() 1750 Posts Member #: 10190 Post Whore belgium |
28th May, 2020 at 08:26:23pm
It doesn't get to hot for locking nuts? you can do anything if you set your mind to it...
28th May, 2020 at 08:54:19pm
1st Jun, 2020 at 01:38:05pm
Thanks Chaps
1st Jun, 2020 at 10:57:17pm
Some facts to add to this lads,,,
3rd Jun, 2020 at 02:57:30pm
that does make it more easy in a way. ( with the nuts) as you can just insert long enough bolts trough do up the nuts and then cut off the exces if i see it correct? ( with the bushes in and so on of course) you can do anything if you set your mind to it...
27 Posts Member #: 11884 Member |
3rd Jul, 2020 at 03:57:30pm
if this isn't a silly question... at what point do you need to go RTS because a standard turbo verto starts slipping? |
5th Jul, 2020 at 09:43:58am
On 3rd Jul, 2020 NDT said:
if this isn't a silly question... at what point do you need to go RTS because a standard turbo verto starts slipping? I'm not sure, but the RTS is rated up past 200hp of that takes your fancy and of course it is kinder to the thrusts as well. |
5th Jul, 2020 at 09:45:47am
depends, Ive know orange plates to hold 140hp, sor some slip at 90, likwise with the verto's, all in good nick though you can probably put about 120 hp through a turbo verto, then theres to "20% uprated one" so really if your looking at over 150 hp its a must. On 28th Aug, 2011 Kean said:
5th Jul, 2020 at 11:07:48am
On 28th May, 2020 Rammie2000 said:
It doesn't get to hot for locking nuts? I used loctite 270 also ![]() Outside the box |
Site Admin ![]() 9404 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
20th Oct, 2020 at 09:53:12am
Two questions, what weight have you managed to get the RTS assembly down to, and what RPM have you used it at?? Team www.sheepspeed.com Racing
20th Oct, 2020 at 09:30:58pm
Tnx. Really need to get going on it again. Build the engine 3 years ago...
It doesn't get to hot for locking nuts? I used loctite 270 also ![]() you can do anything if you set your mind to it...
23rd Oct, 2020 at 09:29:17pm
On 20th Oct, 2020 Jimster said:
Two questions, what weight have you managed to get the RTS assembly down to, and what RPM have you used it at?? I have found you want it heavy back to back tests shows it comes off the line better. mine has been to 8k 18 times in one weekend and still have my balls, the way they are put together means for it to brake free all 6 m10 bolts would need to pull out of the cover back plate. I have started posting on Instagram also my name on there is turbomk1golf
23rd Oct, 2020 at 09:30:58pm
if this isn't a silly question... at what point do you need to go RTS because a standard turbo verto starts slipping? I'm not sure, but the RTS is rated up past 200hp of that takes your fancy and of course it is kinder to the thrusts as well. Me and alex tested one on the bench and it got up to 240flb before it slipped, I was swinging off it in the end. I have started posting on Instagram also my name on there is turbomk1golf
2636 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
24th Oct, 2020 at 09:00:03am
if this isn't a silly question... at what point do you need to go RTS because a standard turbo verto starts slipping? I'm not sure, but the RTS is rated up past 200hp of that takes your fancy and of course it is kinder to the thrusts as well. Me and alex tested one on the bench and it got up to 240flb before it slipped, I was swinging off it in the end. Shane Edited by shane on 24th Oct, 2020. |
24th Nov, 2021 at 11:18:22am
Last time i looked the AP pressure plates were out of stock but are in stock now!
24th Nov, 2021 at 09:46:28pm
My first attempt at an RTS I used one green and one blue and the pedal was as heavy as a pre veto with grey diaphragm.
Page: |
