Page: |
Home > General Chat > Throw Out Stop | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
14th May, 2020 at 03:23:30pm
I've run engines with and without a throw out stop, without any issues. I've herd people say if you don't have one it will destroy thrusts / crank. I understand how it works, but surely with or without the throw out stop the same pressure is exerted on the crank thrusts when disengaging clutch ? So how is it of any benefit ?
15th May, 2020 at 02:35:33pm
think its mainly for pre verto setups? to stop the diaphragm from over throwing? My build thread..
13 Posts Member #: 11919 Member Norway. |
10th Jun, 2020 at 02:39:28pm
Very early Minis had no throw out stop at all I seem to remember, not sure when the stop was intorduced but about the same time as the "Deva Bush modification was effected after the 997 Coopers were "new" and the oil fed primary drives were fitted to the original 850 Mini.
Edited by Anthony C. Thomas on 10th Jun, 2020. Best wishes
10th Jun, 2020 at 02:57:26pm
The early oil fed primary drive gear and crankshaft were 1/8" (3.2mm) smaller than its prediscessor 22G178 which is 1.5" diameter. The smaller older crank was stamped 22G153 (1 - 3/8" diameter).
Best wishes
10th Jun, 2020 at 11:24:30pm
I have not had any for years tbh, I just chopped the end off and sorted it out in the lathe. I have started posting on Instagram also my name on there is turbomk1golf
Page: |
