Page: |
Home > General Chat > Cam Timing | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
8th May, 2020 at 11:30:28am
I've got an MED Piper 310 SP camshaft, with 107 stamped on the end. I would normally time 1 degree less allowing for chain stretch, but just wondering what does anyone else do ? http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
7 Posts Member #: 11775 Junior Member Australia |
15th May, 2020 at 11:39:26am
On my last build I did the timing with the head and valve gear on, so that the chain was loaded up when rotating the assembly. Found this made a difference of 1 to 2 degrees. This was with new gears and Irwin double chain. 1962 / 66 Mini Monaco under restoration
Page: |
