Page: |
Home > 998cc > 998cc with 12G940 project | |||||||
3 Posts Member #: 11961 Junior Member |
7th Jan, 2020 at 09:47:37pm
Hi all,
80 Posts Member #: 11548 Advanced Member Calne Wiltshire |
7th Jan, 2020 at 11:54:40pm
First thing that I would suggest is check the engine number on the block is it definitely a 998 with a 1275 head or a whole 1275 engine? |
14th Jan, 2020 at 01:28:29pm
This is what I'd do
![]() 1750 Posts Member #: 10190 Post Whore belgium |
31st Jul, 2020 at 09:07:21pm
If it's a 998 with 1275 head and you change valve lift in any way. Check if your pockets are deep enough so the valves don't hit the blok or come to close to it. you can do anything if you set your mind to it...
Page: |
