Page: |
Home > General Chat > Emerald and Mac | |||||||
2636 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
17th Nov, 2019 at 10:03:01pm
Evening all,
17th Nov, 2019 at 10:25:30pm
Run a Windows emulator on it or something similar. So the program thinks it's running on a windoes machine |
173 Posts Member #: 9128 Advanced Member |
18th Nov, 2019 at 01:31:41am
As above or you could partition the hard drive, effectively making 2 hard drives and install windows straight on one of the partitions. |
18th Nov, 2019 at 02:40:42pm
Thanks for the reply’s.
18th Nov, 2019 at 04:21:42pm
I bought a cheap laptop for £60 that had a serial port to use for Emerald. Failing that Jimbo will be able to help you with the Mac |
18th Nov, 2019 at 04:55:04pm
On 18th Nov, 2019 t3gav said:
I bought a cheap laptop for £60 that had a serial port to use for Emerald. Failing that Jimbo will be able to help you with the Mac ![]() I done this, bought a cheap laptop to use for megajolt. Im not clued up enough on IT to tell you how to do it, i just know thats roughly a way to do it |
18th Nov, 2019 at 09:19:54pm
I bought a cheap laptop for £60 that had a serial port to use for Emerald. Failing that Jimbo will be able to help you with the Mac ![]() I done this, bought a cheap laptop to use for megajolt. Im not clued up enough on IT to tell you how to do it, i just know thats roughly a way to do it Shane |
18th Nov, 2019 at 10:32:43pm
Partition you drive is a piece of piss Shane, you've got all the software you need already.
Page: |
