Page: |
Home > General Chat > New panels | |||||||
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
14th Jan, 2019 at 09:21:34am
Alright guys, I'm going to be buying a load of panels soon to start with the body work. What would you recommended going for that will need the least amount of faffing to get them to fit/best quality? Gen? Non gen? M machine? I need a whole new front end, including the scuttle. Complete new floor, heel board, flitches ect
They don't die, they just get faster! |
264 Posts Member #: 11029 Senior Member Crewe |
15th Jan, 2019 at 11:15:10pm
M machine get good ratings however I've used midnight and m machine you have to piss about with them all even heritage plus it also depends what's been used previously I did buy a genuine heritage scuttle I have 3 in the workshop now bought at 3 different years and all are different you can see how the tooling has deteriorated. Buy the best you can afford Edited by monsterob on 15th Jan, 2019. Outside the box |
45 Posts Member #: 11153 Member |
16th Jan, 2019 at 10:50:11am
Is this for for Mk3 car? If so you are in a better position than for Mk1 or 2. This is because there are relatively few early panels pressed, most are converted later panels (eg rear seat/boot floor panel).
16th Jan, 2019 at 06:53:17pm
My car hasn't had any body work done on it for the last 3 years which was when the rear end was done. Over five years ago I had my front panel and one wing changed both were non gen, the front panel fit well but the wing not so much. By the sounds of things it's just pot luck of who you buy from and what fits best on different panels. Edited by Shauna on 16th Jan, 2019. They don't die, they just get faster! |
17th Jan, 2019 at 11:37:29am
This doesn't help you, but in upcoming (unfortunately likely to be next year, as I'm working on the house, maybe the garage/garden). I intend to use Heritage when were the correct panels are available or NOS ones, with a mix of M-machine and potentially some of the new Magnum Panels. It is on a Mk1 though hence the increased difficulty.
17th Jan, 2019 at 06:03:32pm
Haha sounds like I'm a year ahead of you, we've been renovating.. Doing grown up stuff so the mini has been sitting patiently the last 6months since I let the MOT run out. Yeah I've heard from a few people before that different brands have different thickness of metal in their panels. I'd say maybe this is why some people favour fibreglass but I've seen some terrible fitting front ends 😂. Mines a mk4 saloon so I haven't got and difficult panels to get a hold of luckily.
On 17th Jan, 2019 Nathan1293 said:
This doesn't help you, but in upcoming (unfortunately likely to be next year, as I'm working on the house, maybe the garage/garden). I intend to use Heritage when were the correct panels are available or NOS ones, with a mix of M-machine and potentially some of the new Magnum Panels. It is on a Mk1 though hence the increased difficulty. I know the heritage front wings are very hit or miss, one side in general is a poorer fit (tooling more heavily worn?), and the headlight reinforcing rings are sometimes welded seemingly by someone with their eyes closed. I've seen a number of people buy two wings, cut the ring off of one without damaging it, cut the ring off the other without damaging the wing and put to two good bits together! Considering the increase in value of mini's now, I would of thought it would start to make sense investment in panel tooling would be an option! Magnum have started to show this with a complete Mk1 floor in one pressing and are developing other Mk1 panels (side panel complete). But I've heard their metal is not the best quality, maybe just someones opinion??? They make a lot of early escort panels. They don't die, they just get faster! |
Page: |
