Page: |
Home > General Chat > KnockBlock G4 vs det cans | |||||||
17th Oct, 2018 at 01:24:57pm
Any real life experiences of the knockblock compared to det cans? Apart from the LED output (which could be great if it REALLY is able to be set and ‘tuned’ as easily as it suggests) what do you really gain? I can see a benefit in having a knock sensor permanently bolted to the engine, allowing it to be plugged into any time, but it’s not like it’s a time consuming job bolting in det cans.
![]() 6748 Posts Member #: 828 Post Whore uranus |
17th Oct, 2018 at 08:22:43pm
see j and s safeguard dave , i use it and i like it . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3591 Posts Member #: 655 Post Whore Northern Ireland |
18th Oct, 2018 at 12:34:25am
I've used lots of electronic devices...and the biggest problem with them all is background noise. Yes they all claim some filtering etc etc...but they're still bloody loud.
Edited by stevieturbo on 18th Oct, 2018. 9.85 @ 145mph
18th Oct, 2018 at 01:20:29pm
I’m first going to try fabricating a different set of det cans, maybe using a thicker hose, maybe with additional insulation, and trying smaller bore hose.
18th Oct, 2018 at 07:06:02pm
J&S is a control unit, not just a listening device though.
18th Oct, 2018 at 10:21:52pm
Well, I used 1/4” ID hose in my last set, and all I could hear was droning noise. I guess I’ll coninue experimenting! On 17th Nov, 2014 Tom Fenton said:
19th Oct, 2018 at 10:10:13pm
I dont think hose size is a big issue. Mine is 10mm on the block into the car, then it tees into the smaller hoses into each earpiece. drilled through side of the defenders and also a hole poked through the foam inside so the tube has a clear path to the ear.
Edited by stevieturbo on 19th Oct, 2018. 9.85 @ 145mph
Page: |
