Page: |
Home > A-Series EFI / Injection > My Journey into EFI | |||||||
6 Posts Member #: 11809 Junior Member |
7th Oct, 2018 at 04:05:49am
I am looking into converting my Mini 1275gt from Carb to EFI. The end goal is to do forced induction. I will start with converting to EFI on a 1275 engine that is currently running a SU 1.5" Carb.
7th Oct, 2018 at 07:51:12am
First thing I would say is get registered on the MS-Extra forums and use the link at the top to download and read the manuals, both for the v3.0 board and the V3.57.
Edited by Rod S on 7th Oct, 2018. Schrödinger's cat - so which one am I ??? |
7th Oct, 2018 at 05:50:25pm
Rod has given a very good and complete reply but I'd like to add something. You don't mention if you're comfortable soldering your own ECU board and make modifications and additions. If that's not something you're comfortable with and/or not something you want to deal with then you need to go with the MS3/MS3X if you go with a Megasquirt solution as the MS2 does require quite a bit of DIY modifications and soldering.
7th Oct, 2018 at 07:37:21pm
Rod, Thank you for your detailed write up. Yes i'm on the wrong side of the pond... Located in the corn fields of Iowa
7th Oct, 2018 at 09:44:53pm
So the MS2 has 1 high current ignition output. Can i Drive all 4 spark plugs with this? or is it recommended to only drive 2 with this? |
8th Oct, 2018 at 05:54:10am
On 7th Oct, 2018 rhcp4life said:
So the MS2 has 1 high current ignition output. Can i Drive all 4 spark plugs with this? or is it recommended to only drive 2 with this? No, not unless you revert back to a single coil and distributor which really is a retrograde step. You could still have the MS control the timing but you would be relying on the mechanical advance being similar so the rotor arm was close enough to the right terminal in the cap to send the spark to the plug or you would have to lock out the mechanical advance such that the rotor arm would always be close enough to the terminal whatever the advance was which isn't always possible unless the rotor arm has a very wide contact area. Once you select wasted spark in TunerStudio the code will send the spark signal out of two different CPU pins alternately so it needs two "ignitors" (or logic level buffers) for the two individual coils inside the wasted spark coilpack. Adding a second "ignitor" transistor to the MS-2 to run wasted spark is one of the easiest mods - apart from lack of space on the heatsink bar if all the standard injector driver components are installed, which is another good reason to decide up front how you are going to approach forced induction later if you go down that route. And totally off topic, as soon as you said "the cornfields of Iowa" the first thing I thought of was Bay City, Tx - I saw "Field of Dreams" when it first came out in the cinema in Bay City (I was living/working in the USA at the time....) Schrödinger's cat - so which one am I ??? |
Page: |
