Page: |
Home > Introduce Yourself > Hi from Norwich - Yam R1 project | |||||||
9 Posts Member #: 11802 Junior Member |
28th Sep, 2018 at 07:03:06am
Hello everyone
28th Sep, 2018 at 09:05:05am
Sounds like fun. The Rotrex supercharges can work well on bike engines, they're used extensively in hillclimbing.
28th Sep, 2018 at 10:12:34am
I guess I am showing my noob lack of knowledge. I was thinking the drive could come from the output shaft of the R1 gearbox which connects to a chain system on the Promotive conversion kit I will be installing.
2094 Posts Member #: 9894 Post Whore Dorking |
28th Sep, 2018 at 12:49:31pm
Would of imagined you need engine speed to drive it, so straight from the crank rather than driven of the gearbox as that will mean it’s spinning at the wheel speed rather than engine rpm. |
28th Sep, 2018 at 02:41:45pm
On 28th Sep, 2018 jonny f said:
Would of imagined you need engine speed to drive it, so straight from the crank rather than driven of the gearbox as that will mean it’s spinning at the wheel speed rather than engine rpm. Yes you are correct and I realized that after posting this morning (and after a bit of googling). Driven off the crank is feasible if I can overcome the relocation of the stator perhaps by replacing with an alternator that's driven by the same drive belt. Perhaps a turbo will be a better option?! |
28th Sep, 2018 at 02:48:15pm
Yeah. Needs to be from the crank, or you'll get more and more boost as you go through the gears. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
81 Posts Member #: 11403 Advanced Member |
28th Sep, 2018 at 05:06:54pm
Would it not be easier going with a turbo instead? |
28th Sep, 2018 at 09:48:18pm
On 28th Sep, 2018 steve2016 said:
Would it not be easier going with a turbo instead? I am quickly discovering the answer to that is yes! I've found quite a good guide on the R1 forums detailing a turbo conversion. Seems like a much easier route than the work involved to supercharge |
Page: |
