Page: |
Home > Introduce Yourself > Mega squirt 2 in turbo 998 moke. | |||||||
4 Posts Member #: 11764 Junior Member |
3rd Jun, 2018 at 02:15:35am
Just joined up to share the crazy! I have a 998 running turbo and Megasquirt 2. on my engine testbed. Still trying to understand the American terminology for getting the cranking fuel right for starting .
62 Posts Member #: 11458 Advanced Member Melbourne Australia ... not a convict |
3rd Jun, 2018 at 09:19:33am
Welcome Stewart .... Cheers Jon 1977 Leyland mini Sunshine -- moleseted -- Named " Ray" becoming a 7 port efi slowly
4890 Posts Member #: 1775 Post Whore Chester |
3rd Jun, 2018 at 10:46:08am
Welcome I run a supercharger and I don't care the TB is on the wrong side.
3rd Jun, 2018 at 02:21:35pm
Welcome.
4th Jun, 2018 at 12:31:20am
Yes in Brisbane, Australia. I got involved with it as I have a testbench I built for setting up engines from scratch to run engine management. The MS2 is the hardest manual to understand I have ever encountered. Doesn't seem to be logical in explanation to me! However the more I think about the terminology I guess the more I understand. Thanks friends, I'll post some images soon.
4th Jun, 2018 at 01:48:03pm
Re. the documentation it depends on exactly what you have got. Providing you are using the MS-Extra code the documentation went through a major upgrade about 4 years ago and, IMHO, is now very good. However, lots of people still end up looking at the old B&G code documentation which is years out of date because hardly anyone uses the B&G code anymore.
28th Aug, 2018 at 03:12:01am
So the engine is tuned and fitted. I ran batch fire with 2 injectors and wasted spark. Engine will pull smoothly at light throttle and spins easily to our 5900 cut off . At 6 psi it pulls easily to 50 kph in low 90 in second and we haven’t had room to pull through 3 rd yet. I used software to help with ignition predictions as well as fuel. We have no bumps or harshness. E temp at cruise and loaded sits on average at 1200 F. Very happy with the result. If any one would like to see the ignition map I can email it to them. I tuned the idle ignition using air fuel meter and my prony brake. 10.7 deg was perfect loaded to 90kpa at 600 rpm. Nice feeling to get it done . I also found the idle ignition to map a great idea |
28th Aug, 2018 at 08:43:36am
Sounds like fun. 998s will happily spin to 7k, so you have plenty to play with.
28th Aug, 2018 at 05:04:19pm
Is your setup using port injection or a throttle body? If it's port injection, using batch injection is not ideal for getting good fuel distribution and you can have wildly different AFR values between the inner and outer cylinders. |
28th Aug, 2018 at 09:54:09pm
Port injection 1 inj per port, 2 inlet runners with a throttle in each before the injector. Rev limet and boost limit to preserve the rest of the driveline. It runs an aftercooler and is extremely flexible. Photo's to come.
28th Aug, 2018 at 10:35:47pm
It's nice that the engine seems to be running well but that may be hiding some potential issues that could damage the engine later on.
Page: |
