Page: |
Home > Beginners Tech > Help Picking Target CR and Boost | |||||||
16 Posts Member #: 11753 Member Athens, GR |
7th May, 2018 at 11:58:31am
Hello,
For the love of cars!! |
553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
7th May, 2018 at 06:40:22pm
With a decent cylinder head and build etc @8.6:1 comp ratio, I would have thought 11 psi would make 140 ish bananas. Need an intercooler at that boost Edited by dazibee on 7th May, 2018. |
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
7th May, 2018 at 08:08:41pm
Depending on the engine spec 10-12psi should make your HP target. Even on an efficient turbo you'd ideally want an intercooler at that kind of boost otherwise you're just throwing free power away. You'd also have to run a lower compression ratio and more ignition retard, lose, lose IMO.
8th May, 2018 at 12:55:57pm
Thanks dazibee and Turbo Phil!
8th May, 2018 at 01:13:02pm
intercooler, foolproof tech (almost)
9th May, 2018 at 09:57:45am
You could tie the water injection system into your ignition system, or, more directly, intake temp. If you run out of fluid or the intake temp takes off, you could program the ignition system to retard. |
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
9th May, 2018 at 10:37:20pm
On 9th May, 2018 metroturbo said:
You could tie the water injection system into your ignition system, or, more directly, intake temp. If you run out of fluid or the intake temp takes off, you could program the ignition system to retard. Or use a low level switch to switch to a lower “safer” level of boost? Shane |
9th May, 2018 at 10:37:23pm
Boll@@@s Edited by shane on 9th May, 2018. |
10th May, 2018 at 05:19:13pm
Ok all this is great feedback and since I am fairly proficient with electronics (I have built a 3D printer a drone and worked on many Raspberry Pi projects before) I am getting excited about building a smart turbo classic mini!!
10th May, 2018 at 06:57:40pm
check out Speeduino,
10th May, 2018 at 07:41:27pm
Great stuff Joe, looks very interesting!
10th May, 2018 at 07:51:46pm
True, but in my opinion, on a turbo motor its WELL worth having an ecu to be able to log stuff, especially boost and AFR, and in your case if you really dont want to go the intercooler route ( I really really would fit an intercooler) then logging air temps will be really worthwhile during testting/ setup.
11th May, 2018 at 11:14:06am
I'm with Joe, the Speeduino is well worth a look esp. if you are familiar with Arduino and its code generally. I'm playing with one at the moment as a side project.
14th May, 2018 at 12:33:05pm
Thank you guys, I am officially convinced and will incorporate the speeduino into the build! Will probably start a thread on its own when it is in the making.
14th May, 2018 at 12:59:30pm
I strongly think you should also be “officially convinced” to fit an intercooler.
14th May, 2018 at 05:01:53pm
Hi Shane, and thanks for the feedback. I'm sure you know what you're talking about and I value your opinion. Unfortunately the intercooler limitation is there because I will also use the car to participate in historic racing so something as eye-popping as intercooler will be hard to "support", whereas a setup similar to the Metro Turbo or ERA Mini with just a plenum will be more in line with the spirit of the historic racing club.
14th May, 2018 at 08:31:30pm
It really depends on how discrete you need to be for the rules of your historic racing class (where are you based ?).
2094 Posts Member #: 9894 Post Whore Dorking |
15th May, 2018 at 07:14:01am
I can't say i have ever heard of racing regs that would allow you to turbo a non turbo car and fit a modern ignition setup but not fit an intercooler because its not period. not to be rude but it sounds a load of rubbish to me?
16th May, 2018 at 02:44:27pm
Hi Jonny,
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
20th May, 2018 at 07:33:36am
We're running 10 psi on our 998T with no intercooler with no issues. We are going to fut one fir 12psi eventually but other than not getting possibly the full amount of available power by not having one, it's been okay. It does get a little warm on hot days but that's probably down to still using stock cooling still. On 26th Jan, 2012 Tom Fenton said:
23rd May, 2018 at 02:37:52pm
Thank you for your input carlzilla, it is encouraging to know that it has been done before with success!
Page: |
