Page: |
Home > Non-Mini Discussion > Other Siamese Port Engines | |||||||
16 Posts Member #: 11718 Member |
10th Mar, 2018 at 07:36:33pm
Moving the non-Mini content from: http://www.turbominis.co.uk/forums/index.p...id=416587&fr=50
On 10th Mar, 2018 jbelanger said:
Rod, your assumption was correct. The siamese code is limited to a 4 cylinder engine and the 2 additional channels are for staged injection. There may not be an error code thrown if you try an 8 cylinder setup but that still won't work correctly. Thinking about it, it would be possible to use the MS2 with 4 channels and set it as a 4 cylinder fully sequential injection. That would allow using it as a single pulse setup the same way MS3 is being used. The advantage of using the MS3 is that you don't have to cheat and you can configure it as an 8 cylinder but you do waste half of the injector outputs (but you get the other MS3 features). Jean Jean, Thanks for your helpful reply and recommendation of going MS3X. I assume you meant use high impedance injectors and like the MEMS system use all 8 injector channels but driving only 4 injectors? But I assume that even going the MS3X route won't allow for 8 cylinder sequential injection using 4 injectors plus an additional 4 injectors staged? I assume to do that would require using 2 MS2 setups with them each running half of the engine? Both think it is only a 4 cylinder engine. However at 25% duty cycle a 1,275 cc/min injector would support the likely power 400 hp from 8 cylinders, similar to 200 hp from a A-series. I guess that with that size injector it wouldn't idle well without major adjustment to fuel pressure which would make tuning tough? Thanks, John R. John R. |
10th Mar, 2018 at 08:52:48pm
John,
10th Mar, 2018 at 10:27:21pm
Thanks that is super helpful. From this it seems like MS3X would definitely be the most straight forward way to do this if staged injection isn't needed.
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
11th Mar, 2018 at 07:28:40am
On 10th Mar, 2018 johntrhodes81 said:
Has anyone gotten and A-series to idle on 1,275 cc injectors? Not that I'm aware of. If you consider it's only in a true port injection setup using timed injection through open valves that requires such low duty cycles that very large injection capacity is required, the obvious answer becomes staged injection. I can't remember the exact timeline in the early days of developing the MS2-E siamese code (I wasn't involved right at the beginning) but the addition of allowing the two individual pulses to switch to one long pulse overlapping both valves (the so called hybrid mode) and adding staged injection were the ways of squeezing a little bit more out of small injectors or just adding more injectors. The hybrid mode actually came about because in the early days we found that if the two individual pulses grew in width to touch each other accidentally they didn't always merge nicely (plus you didn't really know what was happening with close/open times at that point) but it did mean you could have a total duty cycle a bit larger than the "safe" limit for two individual pulses. And staged injection just makes it easier still. We didn't find out until a fair bit later that switching between two individual pulses and a single long one was what Rover had also done with the MPI MEMS. Use of an MS3 as pioneered by Paul to just use a single (timed) pulse came later because the MS3 came later.... So given those options on a 4 cylinder there is no need to exceed 1000cc. Out of the people I'm most aware of doing anything like this (and that includes use of other ECUs which also allow timed injection) I think I'm the only one using 1000cc and that's only because I still haven't completed my staged injection manifold. My idle is fine but, IMHO, there is more to it that just the injector size - I believe the injector characteristics and drive circuitry play a significant part in their performance at the very low pulse widths you need for idle with large injectors. In our scenarios the idle pulse width is almost certainly going to be in the non-linear range and an area where the manufacturer doesn't even document the performance because you shouldn't be there. But my only real justification for saying that is Graham T borrowed my spare pair of 1000cc injectors and my spare MS2 (different drive circuit to his because my injectors are low-z) a few months ago and did a comparison against his (slightly smaller) high-z ones. But it's all rather subjective, no empirical data, plus different manifold, different cam, lots of other differences, how good do you need your idle to be ??? Final thing to bear in mind before I ramble on too much, there are very few people doing this (timed port injection on siamese ports) - most people take the easier option of some sort of throttle body/wet manifold/electronic carb, whatever you want to call it and just live with charge robbing, just like with a carburettor. And when you use that kind of setup you're back to 85-90% duty cycle and "normal" size injectors. Schrödinger's cat - so which one am I ??? |
11th Mar, 2018 at 03:11:51pm
Rod S,
11th Mar, 2018 at 04:14:13pm
Rod S, I was reading some of you other posts on idle, what spray pattern are your injectors?
12th Mar, 2018 at 02:46:54pm
On 11th Mar, 2018 johntrhodes81 said:
Rod S, I was reading some of you other posts on idle, what spray pattern are your injectors? I'll let you know what info I have later in the week when I'm back home - I'm the other side of the Irish Sea at the moment (seeing relatives) and no access to my files (and very little access to the internet...). Schrödinger's cat - so which one am I ??? |
13th Mar, 2018 at 11:26:42am
Jean,
Page: |
