Page: |
Home > For Sale > Custom head gasket | |||||||
398 Posts Member #: 793 Senior Member Milton Keynes |
18th Feb, 2018 at 11:11:44am
Not sure what avenue to go down, as I need an A-series gasket with different bore & bore spacing's (unable to mod any standard ones to fit). Cometic are very good but expensive for low production. So looked into copper. Spoke to Mike at Ferriday and he wasn't keen to supply as he felt A-Series engines are a nightmare to seal and pointed be back to cometic. Surely a dry deck / well made and correctly fitted copper or copper with s/steel rings would be good. Top end drag engines use copper with plenty more compression and power than a little old A-series. Does anyone have experience with Ferriday gaskets ?
6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
18th Feb, 2018 at 06:52:06pm
Iv'e used Ferriday gaskets in the past Gav and at the time I though they were the answer to my problems,but on reflection it was head block face deformation that was my problem,i have since gone back the bk450 on the Don,
Page: |
