Page: |
Home > General Chat > Fuel tank outlet size. | |||||||
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
10th Feb, 2018 at 10:31:25am
So after an interesting discussion arose in one of the Faceache groups it got me thinking.
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
10th Feb, 2018 at 12:24:55pm
For power outputs typical on this forum, flow rate through a 6mm pipe is probably fine but pump performance becomes the issue.
3591 Posts Member #: 655 Post Whore Northern Ireland |
13th Feb, 2018 at 09:08:29pm
Whilst you may get away with 6mm....you cannot say because power outputs are low it is fine.
Edited by stevieturbo on 13th Feb, 2018. 9.85 @ 145mph
14th Feb, 2018 at 01:01:11am
As long as pump manufacturers insist on the silly unnecessary practice of putting these large bore inlets to the pumps, I’ll keep using supply lines the same size. On 17th Nov, 2014 Tom Fenton said:
14th Feb, 2018 at 07:47:56am
I’m was going to say what did the MPI tanks have? I run a supercharger and I don't care the TB is on the wrong side.
14th Feb, 2018 at 09:46:42am
i will say that my return line is 8mm the same as feed and the reg cant reduce the pressure correctly i suspect the fitting into the tank/pump hanger flange however if i did it again id just use 10mm ret and 8 feed or a smaller volume pump... |
14th Feb, 2018 at 11:58:20am
On 14th Feb, 2018 gr4h4m said:
I’m was going to say what did the MPI tanks have? No doubt a pump that doesnt flow a lot of fuel given say a 100bhp demand at most ? 9.85 @ 145mph
14th Feb, 2018 at 11:59:49am
On 14th Feb, 2018 Turbo This.. said:
i will say that my return line is 8mm the same as feed and the reg cant reduce the pressure correctly i suspect the fitting into the tank/pump hanger flange however if i did it again id just use 10mm ret and 8 feed or a smaller volume pump... I had zero issue with the metro turbo reg with 8mm feed and return. Metro turbo/Bosch EFI pump and a 12mm feed from tank to pump via internal strainer. 9.85 @ 145mph
14th Feb, 2018 at 03:55:19pm
I did have a problem running large bore feed and return; couldn’t get the pressure low enough. I ended up putting a sleeve into the rubber feed hose just before the reg; basically reducing the flow potential of the feed, and I was able to reduce down to almost zero psi. On 17th Nov, 2014 Tom Fenton said:
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
14th Feb, 2018 at 04:04:15pm
No trouble with anything using 8mm feed and return. |
Page: |
