Home > Introduce Yourself > 1275gt - turbo
Project_1275_GT
Member #: 11707
Hi
Im about to start the mass renovation of my 1275gt. As i do not have the original engine I have decided to fit a metro turbo unit. Just wondering if anyone can advise on fitting the turbo box available from mini sport? I have one arriving tomorrow.
Are there any issues with these turbo boxes and will it all fit ok when i finally install the engine. dont like the idea of welding it all in, painting then being disapointed when the engine dont fit.....
Thanks
If it's the generic bulkead box there
shouldn't be any particular issues fitting it. Though you need to seam weld the joints on the box completely as they're usually only spotted together.
Phil.
Project_1275_GT
Member #: 11707
Thanks
Does it require complete seam weld due to the heat its exposed to from the turbo?
no, any structral shell welding needs seam welding otherwise its an MOT fail.
the other altenative is to get a modern smaller turbo and a stainless manifold from Fusion fabs
jonny f
Member #: 9894
Dorking
Welcome.
Project_1275_GT
Member #: 11707
not sure whats happened but it only shows me pictures of cats???
