I bought a bridge like the one in the link below.
http://www.oldclassiccar.co.uk/vintage/laycockcarlift.htm
Seen it working. So no problem there.
I installed it at home cleaned it ( the man who i bought it from never maintained it just covered everything in a big fat layer of dirty grease and oil...)
But now 2 questions rise.
1 what grease should i use for the screw and sprocket and chain system ( each pole has a sprocket connected to a spindle for going up and down and all 4 are connected with a chain) i cleaned it all with diesel...
2 the engine is connected to a reducer/ gearbox that filled with oil.
The oil in there was probably never replaced. So drained it and cleaned it.
The idea here was to use 20w50 ( easy from the mini) or 80w90 gear oil.
Whats your toughts on it.
