Home > Wanted > Metro Turbo Crankcase Breather Valve
Anyone have a Metro Turbo Crankcase Breather valve going spare? Its the valve that is normally screwed into the banjo bolt in on the inlet manifold for the servo vacuum take off.
Also looking for the red and grey plastic vent valve that tees into the airbox/ air inlet duct. Trying to find a picture, will post up shortly.
Thanks in advance
Edited by Sprocket on 1st Jan, 2018.
Cybertjuh
Member #: 10689
Heinenoord, The netherlands
I had one for sure. But don’t know if i still got it. Have a look this evening.
Hope for you i didn’t bin it. Had a big cleanup
I managed to find new valve, the that screws into the manifold. I'm still on the look out for one of the red plastic valves though.
Elfturbo
Member #: 2576
South Staffordshire
Has anyone ever found a supplier for the red plastic valve pictured above? They were used on all the MG turbos, I also saw one on the breather on a 205 Rallye. They have 'simca' and 'Metfiltre' written on them. They must have been used more widely than just MGs
HOSS
