Page: |
Home > Technical Chat > pushrod holes in block | |||||||
Forum Mod 5933 Posts Member #: 784 9 times Avon Park Class C winner Milton Keynes |
28th Dec, 2017 at 01:59:55pm
Ive always had slight witness marks on my pushrods where they are contacting the block, have any of you lot ever opened them up a touch for clearance? I seriously doubt it! |
1849 Posts Member #: 672 The oversills police Oslo, Norway |
28th Dec, 2017 at 07:18:40pm
I had a chat about this with my engine builder. (Builds miglia and historic engines) He used to try to use custom push rods or open the holes up, but it ended up being more trouble than it was worth according to him. My engine also have these tiny marks on the pushrods |
4890 Posts Member #: 1775 Post Whore Chester |
28th Dec, 2017 at 09:17:41pm
Phil’s your man for the best idea, but didn’t andy have have to sleeve one head as it went though? I seem to remember on the post there wasn’t much meat? I run a supercharger and I don't care the TB is on the wrong side.
28th Dec, 2017 at 10:44:24pm
In my experience, there's loads of meat in the block, unless you've ground a load off the outside if course,
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
28th Dec, 2017 at 11:02:09pm
Is there not pics of a chopped up block somewhere? I have started posting on Instagram also my name on there is turbomk1golf
29th Dec, 2017 at 05:49:32am
Thinking about it, they are also close at the top of the head, it might have been the head that was troublesome to enlarge.
29th Dec, 2017 at 07:56:02am
Looking at the two outermost, they are slightly larger than the rest anyway. Im only thinking of opening them maybe 20 thou or so and probably not all the way through but maybe just the top 1 inch I seriously doubt it! |
109 Posts Member #: 10368 Advanced Member Australia |
29th Dec, 2017 at 08:20:16am
The blocks are a bit variable and the pushrod holrd at some small angle or some are ( if you were going to jig it up). I have bigger diameter lifters in my historic racer .875 i think. ( it is possible to go through and need to sleeve, but for the rubbing just file away ..... no problem and indeed better to put the mind at ease. I have seen a few of these, using OEM and aftermarket rods, i think it is related to rpm???? |
6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
29th Dec, 2017 at 11:28:04am
I've had rubbing marks, but it appeared to be they were form the head gasket miss match as the marks were at that exact place on the rod, this only happened on my super
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
29th Dec, 2017 at 12:43:48pm
Theres a bit in Vizards Bible about the carbon pushrods isn't there? Does it mention drilling them out? |
29th Dec, 2017 at 08:36:56pm
hi lift cam rate , another possibility, ( good thinking)
Page: |
