Page: |
Home > Technical Chat > D.I.Y Ignition Management | |||||||
33 Posts Member #: 11676 Member |
28th Dec, 2017 at 01:23:16pm
Hi all, hope everyone had a good Xmas.
Edited by Ben5004 on 28th Dec, 2017. |
1648 Posts Member #: 9038 Post Whore Carlisle, Cumbria |
28th Dec, 2017 at 01:29:28pm
when you buy megajolt you can choose either TPS or MAP versions. You'll just get the map one and it has the sensor inside and you just attach a vac line to the megajolt unit.
28th Dec, 2017 at 02:53:41pm
Perfect, so that eliminates the need for an external/separate map sensor. So all I should really need to buy is the ecu itself and the loom. Presumably it comes static timed/Base mapped that you then tweak to what you want? |
28th Dec, 2017 at 02:59:34pm
And a trigger wheel! |
28th Dec, 2017 at 03:17:41pm
if you unplug the EDIS then it runs at 10 degrees i think so should get the car running. If you search the web you can normally find a map that might be close to your engine spec. Then you can load that into the megajolt, but obvisouly it wont be perfect so will need some more RR time to perfect it.
28th Dec, 2017 at 04:42:26pm
Somewhere on here is a map that is basically the metro turbo dizzy advance curve on boost, and a NASP type curve off boost. It's a good starting point to create a more progressive curve, and will be a safe starting point. |
Page: |
