| Home > A-Series EFI / Injection > To stage or not to stage | |||||||
17 Posts Member #: 11671 Member |
11th Dec, 2017 at 09:51:46pm
Hello, I am new to the forum, I have a 1275 gt with blow through Eaton m45. Currently on a metro turbo carb but I am in the process of port injecting it.
14th Dec, 2017 at 11:15:46am
You're on the borderline between using 2 large injectors and 4 smaller ones (2 primary and 2 staged secondaries).
Edited by Paul S on 14th Dec, 2017. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
14th Dec, 2017 at 11:57:42am
I would concur with Paul, try 2 x 1000cc and see.
Edited by Rod S on 14th Dec, 2017. Schrödinger's cat - so which one am I ??? |
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
14th Dec, 2017 at 08:19:31pm
According to my datalog from my original dyno session, I hit 25% duty at 4847RPM and 209KPa (15.6 PSI).
’77 Clubman build thread
15th Dec, 2017 at 09:04:01am
On 14th Dec, 2017 Graham T said:
I believe I am on what I thing is the edge of the injectors ability to properly open when on tick over. With Rod’s low z injectors I was able to drop the Injector opening time down to 0.7ms, compared to the 1.2ms I am running the Siemens injectors at. With Rod’s injectors the tick over was much smoother and much more stable, with AFR’s around the 14.1 mark, with My Siemens injectors I need to be at around 13.4AFR to get a reasonable tickover, and then it is still not brilliant. That could be down to the more linear characteristics at low pulse widths of Rod's Low-z injectors. It could also be due to other factors such as spray pattern, voltage variation, location etc, but my money is on the low pulse width issue. Below 2mSec the Siemens have a non-linear characteristic, so you can see big changes in flow for little changes in pulse width which would lead to an unstable idle. MS3 does allow you to define the low pulse width characteristics. All well if you have reliable data. I'm getting a nice smooth idle on 840cc Siemens but I'm using the single pulse method. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
15th Dec, 2017 at 09:46:06am
On 15th Dec, 2017 Paul S said:
Below 2mSec the Siemens have a non-linear characteristic, so you can see big changes in flow for little changes in pulse width which would lead to an unstable idle. Yes, the datasheet for the Siemens injectors shows a minimum operating pulse width of 1.7ms, where on tickover I am running about 1.28 -1.3ms, the data sheet does not even show the linear error % below ~1.6ms. The Characteristic Injector Flow curve chart on the datasheet is not easy to read, but it shows the knee of the curve somewhere around 1.3ms, the knee being the minimum pulse width required to fully open the injector. With my original Manifold, my tickover MAP was IIRC was 38 – 40KPA. Tickover was actually fairly good, but I do not remember the PW it was running. I’m think I had something set up differently back then: IVAC position, Ignition timing or something, because now with the MPI manifold it is pulling 28 – 31KPA at ~980 – 1050RPM when warmed up, hence I think that’s the reason why it’s is now not as smooth as it used to be - it needs less fuel for the lower MAP, so is now operating the injectors with way to low a pulse width. I did start looking at the ASNU injectors, but was not confident enough on my calculations to be sure that they would actually help at low pulse widths, and it’s a lot of money to pay out for something that might not actually be any better. ’77 Clubman build thread
