Home > General Chat > Genuine mpi rads vs alloy ebay specials
JT
Member #: 637
Hertfordshire
HI
While I have my mini in bits I'm thinking of fitting a front rad.
I'd like to keep the intercooler where it is. But reckon that if I move the oil cooler else where I could fit a mpi rad in its place. Obviously I'll have to adust the front panel but should be able to do that and still get the grille on.
My question is, what mpi rad is best these days? Genuine one from minispares or one of these from ebay....
https://rover.ebay.com/rover/0/0/0?mpre=htt...%2F292214613838
I'm running a water cooled gt17 turbo and a electric pump. The engine is also dry decked. I'm hoping to be able to run decent amount of boost so need a decent rad.
Thanks
Josh
Edited by JT on 16th Nov, 2017.
My build thread..
JT
Member #: 637
Hertfordshire
Or there's this one I've found...
https://shop.aseriesspares.co.uk/shop/cooli...ator-dual-core/
My build thread..
I’ve personally found the standard mpi rad a bit marginal on a normal 1380, so a turbo might be a step to far on a hot day in traffix
Edited by minimole23 on 16th Nov, 2017.
D4VE
Member #: 10749
lowestoft suffolk
I take it u will run ya own pipes as it wont fit in the mpis location with your alternator
Nothing gets past Dave lol
JT
Member #: 637
Hertfordshire
I've got a denso alternator on the shelf but I couldn't get it to work. Might try that again failing that, Med do a 60amp smaller one. Bit pricey though.
My build thread..
jonny f
Member #: 9894
Dorking
Fiat cinquecento alloy rad from eBay is working very well for me.
Van used to cook with an MPI rad. I had a cinq rad with a 2wd cossie intercooler above it in my clubby.
Shauna
Member #: 10424
Swansea boyo!
The MPI rad isn't good enough for my engine, it doesn't cope very well during summer. Sitting already baking and then you have to put the heater on to try cool it down a bit haha. But I was wondering how people got on with the ebay specials too as it's definitely something I need to change on mine..
Edited by Shauna on 17th Nov, 2017.
JT
Member #: 637
Hertfordshire
Did you have to move the number plate with that set up John?
I like the way my current intercooler fits and would like to keep it there if I can.
The alloy mpi ones are thicker than the standard mpi ones. And are 2 core. Not sure what a standard type is though.
My build thread..
JT
Member #: 637
Hertfordshire
The aseriesspares one look's better than the ebay ones and nothe much more...
My build thread..
I ran a Chinese one on the Blue Mini never once had overheating issues.
I lowered my number plate on the original brackets and put 4 swaged holes in the front panel, arguably with a bit of ducting that wasn't required.
JT
Member #: 637
Hertfordshire
I think I'm going to go for a ebay side mount special
The 2 core rad that's in it isn't too bad. It just heats up a bit when you hit traffic. I haven't got a mechanical fan and it's about 12 years old so maybe I'm asking too much from it lol.
My build thread..
I'd never run a side mount with out the mechanical fan personally.
Correct. Ive had an "assist" fan mounted on the inner wing before but always in conjunction with the Mechanical
JT
Member #: 637
Hertfordshire
Got a electric fan and it's ducted. I've modified the cowling as well. We'll see.
My build thread..
Give it a blast mate, I think I paid £39 delivered for mine and it was UK Based. And on the 998 I couldnt actually get the car up to Temp.
JT
Member #: 637
Hertfordshire
That for side mount Mike?
I've just ordered one from winner racing. 70mm hopefully get it to fit lol.
I'm running a electric water pump as well.
My build thread..
hazpalmer
Member #: 9038
Carlisle, Cumbria
OT your intercooler is similar shape to mine. Mine was off benny which was a copy of Nics. How does it/where does it attach?
JT
Member #: 637
Hertfordshire
I got it of someone on here. Can't remember who.
It's got two mounts on the bottom of if it on rubeers.
The top is just held by the hoses tbh. When it's plumbed in it doesn't move much. Obviously it moves a bit on the rubbers but if it was solid it would shake to bits.
My build thread..
Yes side mount pal
I ran front mount on the orange mini which monsieur austin made me.
Edited by MikeRace on 23rd Nov, 2017.
