Home > For Sale > Fully worked Turbo crank and A+ ARP rod bolts
This is a 6581 Turbo crank which was in my engine. Ive just picked it up today from MED where it had a crack test, regrind on big ends, mains and a lick on thrust faces, heat treat, polish and check balance.
It is cross drilled, wedged, bladed and back drilled.
Its now effectively an as new crank that you would buy as an exchange unit for around £600 from MED.
Im after £450 with brand new ACL bearings and thrust washers. I would prefer collection or I can bring it to MITP in a couple of weeks
I also have a set of used ARP A+ rod bolts which were in my engine aswell. They were pre stretched and tightened once, they are good to reuse twice more but Im fitting new cos Im building a new engine, these are too good to sit on my bench or throw away so Im offering them £30 posted in uk
I have a set of Titan 1.5 full roller (not just roller tip) rockers again from my engine which are up for grabs, I dont think anyone on here would be interested in 1.5s but if you are gimme a shout
Edited by paul wiginton on 1st Aug, 2017.
Goacher65
Member #: 9652
Maidstone, Kent
Is this still available? Do you know how much they have ground off them now? I presume the bearings are to suit this?
Edited by Goacher65 on 3rd Jan, 2018.
Sorry mate, this went quite a while ago, I forgot to update the post
