Home > For Sale > Fiat Cinquicento Radiator, DAM5656 Gearbox, AN Hardline Flare Fittings, Intercooler, Oil Cooler, Silicon Hoses
Mike-998
Member #: 9774
Buckinghamshire
A few things for sale to get them out of the way:
Fiat Cinq Radiator - £25 + £7 p&p
For sale as I'm no longer having a front-mount radiator, this was bought from eBay and feels surprisingly high quality. Aluminium flat core rather than the brass tubes which I believe is preferred for cooling and is lighter. Plastic end tanks and a threaded hole for a fan switch.
DAM5626 A+ gearbox - £50 collection only
Bought with the block above, and is similarly not needed. This is the later rod change box with three bolt bearing cap (therefore stronger casting). Will include diff (probably shagged) but it does have the 3.44 crown wheel on it to match the pinion in the box. Currently has the layshaft and reverse removed.
Large Oil Cooler – Approx size: 180x150x100mm - £30 + p&p
Audi TT intercooler – Fin damage is fairly superficial from poor packaging when I ordered this. I have spent a little time straightening them since the photo and there is no permanent damage. £15 + p&p
5/16 or MPI Fuel Line flare fittings – Allow the use of re-usable hose fittings (AN), these are -5 to suit the 5/16 MPI feed and return line. Made of stainless steel these are hard wearing and difficult to come across. You will need a 37 deg flaring tool to be able to fit them, any hydraulics shop should be able to help you out. - £20/car set - 4 nuts and sleeves, inc postage
Blue Silicon Boost Hoses:
Blue 63mm 90deg Silicon Hose £10 + p&p
Blue 60-51mm 90deg Silicon Hose £10 + p&p
Blue 25mm, 60mm Straight Silicon Hose (Dump Valve) £5 + p&p
Items can be collected from nr Uxbridge, nr St Albans, or nr Hitchin. Just ask if you'd like me to post anything.
Edited by Mike-998 on 12th Nov, 2017.
Mike-998
Member #: 9774
Buckinghamshire
Block provisionally sold
Second dibs on the block please
ministar
Member #: 10760
Derby
Still got the Rad, Mike?
In St Albans on Tuesday.
James
Mike-998
Member #: 9774
Buckinghamshire
I do still have it but i wont be able to get it to st albans for tomorrow i'm afraid, It's at the garage which I won't be at until the weekend
Mike-998
Member #: 9774
Buckinghamshire
Some more stuff added
