Home > Technical Chat > Reducing rear braking performance.
With a light back end, despite binning the standard brake limiter and fitting an adjustable one my car still has the tendency to want to lock the rears.
Would changing the rear wheel cylinders to increase pedal effort be the 1st port of call, or should I be investigating other issues first?
Regards
James
Edited by minimole23 on 12th Jun, 2017.
05bwardl
Member #: 9991
lichfield ,staffordshire
bigger bore cylinders on the rear should help i would think
3/4 cylinders should be std fitment on anything after the early 70s I think, that's the largest.
Hmmm, I did change them 10 years ago, but they're just what the parts guy gave me, so maybe worth a shot. well, after a measure.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Small rears gives less rear brakes. 1/2" is the smalest.
Yeh, you need smaller bore cylinders on the rear to reduce the braking effort.
I've got the 1/2" cylinders on the rear with the standard limiting valve and you can turn the rear wheels by hand when the brakes are applied hard
doh i was thinkingi t was the other way, brain fart!
think I'll check whats in mine at some point.
jamiestevenbell
Member #: 9941
Derby
I don't know if it's technically the best way to do it but can't you just slacken the rear adjusters off on the drums a little?
All that will achieve is a longer pedal.
Are all bias valves the same ? Which one have you fitted ?
What master cylinder are you using? Single or twin?
Useful suggestions. Seems worth changing the rear wheel cylinders.
Steve, its an unbranded one, and was an improvement, but not quite enough.
Will, its a 1988 Twin Master cylinder.
Dp
Edited by minimole23 on 13th Jun, 2017.
I've never had an issue with locking rears with the same setup you have.
But my car was maybe heavier art the rear, full subframe and I was sat as far back as possible.
Have you filed the leading edge of the shoes? is there any contamination in the drums? Are the hand brake levers free?
These are thing that have caused locking for me in the past; rather than an system issue.
I may change the brake backplates as they are not straight which won't help. Also handbrake levers are free and everything is contaminant free as went over it all the other weekend.
The rear fact I can almost pick the back up probably doesn't help with the locking.
Mirage
Member #: 119
I would go with smaller slave cylinders.
Ive been looking into proportioning valves of late and they can be a bit of a blunt tool. In my mind you cant make a one size fits all valve as even with adjustable ones you are stuck with the same spring rate in it. There is no tech information on how they behave.
So smaller rear cylinders are larger master cylinder ( if thats an option)
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
perhaps the back is fine and the front isn't up to scratch ? no idea what the car is just an idea..
