Home > General Chat > Flywheel balancing Herts/beds area?
JT
Member #: 637
Hertfordshire
Hi
I'm currently making a rts clutch set up. I'll need it balanced in the next few weeks hopefully.
Does anyone know of any places that can balance flywheels?
Also when I take it will I need to bolt it all together as if it was about to go on the engine?
Regards,
Josh
Edited by JT on 29th May, 2017.
My build thread..
AC Dodd has done some for Sprocket I belive, hes just the otherside of the dartford crossing so not a million miles away,
jonny f
Member #: 9894
Dorking
Leave the plate out.
JT
Member #: 637
Hertfordshire
Hoping there's somewhere a bit closer...
My build thread..
MatthewPettitt
Member #: 9237
Banbury
http://tandlengineeringbedford.co.uk/
Are these a bit closer? - south of Bedford, just off the A6.
I took it assembled.
Can't remember for the life of me how much it was though.
JT
Member #: 637
Hertfordshire
Cheers mate. Did they do it while you waited? Or did they have it for a few days?
My build thread..
dazibee
Member #: 1356
TRURO, CORNWALL
Send it to AC Dodd. Leave the plate in and at the same time ask him to machine the horns down so the spring is almost flat. He made a nice job of mine.
dazibee
Member #: 1356
TRURO, CORNWALL
Cos if the spring aint flat you would be wasting your time, which was my mistake
JT
Member #: 637
Hertfordshire
Surely shortening the spacers would do the same thing as machining the horns?
How much did you machine off?
My build thread..
dazibee
Member #: 1356
TRURO, CORNWALL
I had aprox 35 thou machined off the horns. It will depend on how thick your clutch plate is. They vary in thickness.
MatthewPettitt
Member #: 9237
Banbury
They had it for a few days.
JT
Member #: 637
Hertfordshire
They can't do it without the crank apparently :/
My build thread..
jonny f
Member #: 9894
Dorking
Took mine to KAD bit far for you!
NDT
Member #: 11884
Thread resurrection...
Who did you use in the end OP?
