Page: |
Home > General Chat > Terminal removal tools | |||||||
27th May, 2017 at 07:22:01am
I need to replace some of the terminals in the loom on my daily drive. Looking to just replace the terminals that are damaged with parts from a donor loom, rather than splice the whole terminal block in. So I'm Looking for a recomendation for a set of terminal removing tools, before I buy shite from ebay.... What's worked for you? On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
27th May, 2017 at 07:52:17am
Which terminals ?
27th May, 2017 at 07:59:25am
Thanks Rod
27th May, 2017 at 02:42:13pm
keith got a couple for working on the VAG stuff. I'll find out what and where he got them for you
3591 Posts Member #: 655 Post Whore Northern Ireland |
27th May, 2017 at 05:37:19pm
On 27th May, 2017 Rod S said:
Which terminals ? But, to answer the question, I have these https://www.durite.co.uk/itm/Terminal-Conne...Tool-Set/070399 I got them direct from Durite as part of a deal as I was buying their cable crimping tools (for which they have a very good reputation) but they are available from other automotive suppliers and even eBay (assuming the ones on eBay are genuine and not chinese copies). They cover most common terminals/connectors but every now and then I still have to grind down a bit of metal bar or welding tungsten to make a "special". That set looks like very good value even more so as quite a few options on it. But as you say, there are loads of different types. 9.85 @ 145mph
27th May, 2017 at 06:20:33pm
On 27th May, 2017 Rob Gavin said:
keith got a couple for working on the VAG stuff. I'll find out what and where he got them for you Thanks On 11th Feb, 2015 robert said:
3rd Jun, 2017 at 05:36:45pm
Ended up buying a generic looking VAG specific terminal tool from egay. The one that arrived was much better quality than expected and most importantly did they job well.
Page: |
