Page: |
Home > Help Needed / General Tech Chat > Mini gearboxs | |||||||
32 Posts Member #: 10074 Member new Zealand |
22nd May, 2017 at 10:32:35pm
Hi guys... quick question what gearboxs are you using under your turbocharged minis?? And what power are you making??
23rd May, 2017 at 07:38:52am
On my road car, running 10psi and making at a guess 110 it's totally standard. Up to 130 bananas I be happy to keep it standard.
23rd May, 2017 at 07:51:17am
generally people are mostly running the minispares clubman kit, and putting lots of oompf through it, certainly it will take 200 brake reliable as long as its built right.
23rd May, 2017 at 08:47:02am
Thanks for your replys guys... I only have a factory 1275 gearbox I don't have a factory turbo box will this be a problem. Or will mine be ok?? Il have a look at the clubman kit now |
23rd May, 2017 at 08:49:27am
The turbo box was just a standard box, nothing special.
23rd May, 2017 at 08:55:19am
I see ,that I didn't know.... not many turbo here in nz so not much info on turbo engines /boxes unless reading in a magazine..... I'm hoping for around the 120-140hp Mark so maybe itl be ok with a factory box then...just saw that clubman kit that seems ok.. So do you guys use just the standard diffs as Well?? |
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
23rd May, 2017 at 09:16:59am
No, an uprated diff with the turbo torque is pretty much essential. The standard diff can give problems in a normally aspirated 1275. The 4 pinion diff a good starting point.
23rd May, 2017 at 09:29:07am
Maybe for a start if I use a standard gearbox with a 4 pin diff? |
6729 Posts Member #: 618 Post Whore Glasgow |
23rd May, 2017 at 09:30:56am
I've managed to destroy a standard box with mine running perhaps 130bhp. I'm now running SC box with 4 pin diff however using helical drop gears Edited by Rob Gavin on 20th Jun, 2017. |
23rd May, 2017 at 09:39:19am
Just trying to get people's opinions on what to do... |
23rd May, 2017 at 10:39:58am
Apart from the internals, if you haven't already (and assuming we're talking rod change boxes), try and source the later DAM5626 casing, not the early DAM2886.
9 Posts Member #: 11577 Junior Member |
20th Jun, 2017 at 08:15:54am
I went with Minispares ST SCCR also and so far I have no issues with it. |
5 Posts Member #: 12060 Junior Member |
9th Aug, 2022 at 07:48:37am
If you are in NZ probably not many A+ boxes there, I'm in Australia and building a turbo 1275 but I've got an earlier rod change box, not a+, do people reckon I'll be right with jus a moderate increase in power on the standard pre a+ rod change, but with a cross pin diff? I'm probably thinking 120hp but that's just a guess. |
Page: |
