Page: |
Home > General Chat > Daily drive advice | |||||||
![]() 1750 Posts Member #: 10190 Post Whore belgium |
17th May, 2017 at 10:52:53pm
My daily jeep ( 2006 l200 2.5 diesel) went to mot and came back with a red cart. Problem... the exhaust particels are to high ( not co but they mesure the no of particels) so i have pourd in some bardal okco to reduse it ( anti pollution stuff ) had a drive on the main road 120 in 4th so it makes 4200 rpm at 120 kmh now tomorrow i have to go back to the mot.
149 Posts Member #: 9991 Advanced Member lichfield ,staffordshire |
17th May, 2017 at 10:57:00pm
prety sure most have a standing idle limiter, what you suggest of restricting the throttle movement should wotk |
167 Posts Member #: 11091 Advanced Member |
17th May, 2017 at 11:35:07pm
Oooo I've got this one!
18th May, 2017 at 07:05:06am
So no idea what helped the most but from 6 out of 10 to 0.4 out of 10 legal limit for my jeep is 3.5 out of 10. ( what makes it a euro 6 car i guess) and max rpm with flooring it was 3800 rpm... 😉 you can do anything if you set your mind to it...
974 Posts Member #: 3228 Post Whore North of the Netherlands |
18th May, 2017 at 09:10:34am
Not sure what regulations you have in Belgium, but in Netherlands 2006 cars (my A4) don't need to go through this test anymore. Dazed and Confused.... |
18th May, 2017 at 11:50:06am
In belgium every car get abused. Even the ones with special filters. While it is perfectly posible to put a diagnostic computer on it instead of reving the shit out of it. you can do anything if you set your mind to it...
18th May, 2017 at 01:32:09pm
You can do forced regeneration on the dpf for most cars.
18th May, 2017 at 05:13:08pm
most correct way to me would be on rolls. engine under load into the normal max rev range. not free spinning way into the dangerous red zone. multiple cars who were doing no problems at all came back from mot here with damaged engine. often higher mileage cars but driven like old people drive them. and if you all the sudden go pushing them like that.... you can expect damage.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
18th May, 2017 at 10:31:44pm
On 18th May, 2017 Paul R said:
You can do forced regeneration on the dpf for most cars. I find it a pain in the ass, in the UK you can get away with removing the exhaust, cut open the dpf and remove the inner and get the software mapped out. But we only have a visual inspection of this. But new April 2017- will have to do a test like Belgium 9n their mot's What new rules are coming in here? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! ![]() 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
Page: |
