Page: |
Home > Technical Chat > Lightweight Battery | |||||||
24 Posts Member #: 10252 Member London |
9th May, 2017 at 08:32:50am
I'm looking for a new lightweight battery. I had a Varley RedTop 15 for the last 4 years but its now dead. Its for a motorsport mini which doesn't get much use. I thought the RedTop would last a bit longer so am not that impressed with it.
9th May, 2017 at 09:34:41am
a varley redtop is as good as any leadacid, I've had ones last a long time and others not, never sure why.
2094 Posts Member #: 9894 Post Whore Dorking |
9th May, 2017 at 10:00:17am
I just typed 'ytx-14 lithium' in on eBay and bought the cheapest one with a charge indication light on the top. JMT one at £65.99 is what I have at the moment. Had it for a year now, no issues. Sat in a single skin garage with not much use all winter.
Edited by jonny f on 9th May, 2017. |
10th May, 2017 at 12:10:22pm
Thank guys.
489 Posts Member #: 9159 Senior Member Devon |
10th May, 2017 at 12:45:59pm
It's a bit on the weighty side? |
10th May, 2017 at 12:58:46pm
On 10th May, 2017 jamestar said:
It's a bit on the weighty side? Its the same weight as the Redtop |
10th May, 2017 at 04:49:35pm
The lithium one I said is around 900g. Cracking cost/weight saving. |
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
10th May, 2017 at 06:33:41pm
Looking to buy one asap.. this the one you got jonny?? Ebay- 331905042785 Do u need a different type of charger to be able to charge it? Edited by D4VE on 10th May, 2017. On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
10th May, 2017 at 07:55:38pm
You need lithium mate. Redtops and all those other 'lightweight' lead acid batteries are out dated tech now and have zero benefit really. We use the 9ah lithium ion batteries on all our race cars now, they have been faultless over two years. As Johnny says 900g for 9ah and plenty to start a race car from cold in webers which takes a bit of cranking sometimes!! |
10th May, 2017 at 08:07:13pm
And no special charger needed, the only thing with them is manufacturers data says don't charge at over 20a iirc. Normal charger on trickle or fast charge will be fine but be careful using start chargers or jump leads. I did wonder whether running them with a 40amp alternator was asking for trouble but it doesn't seem to be I've even jump started before with no issue. They have internal circuitry to regulate the charging current and make we sure the actual cells dont see too much. |
11th May, 2017 at 01:25:26am
Yes that's the one.
On 10th May, 2017 D4VE said:
Looking to buy one asap.. this the one you got jonny?? Ebay- 331905042785 Do u need a different type of charger to be able to charge it? |
11th May, 2017 at 07:59:14am
Thanks for the advise guys. Lithium definitely seems to be the way to go. |
Page: |
