Home > General Chat > Weight savings
05bwardl
Member #: 9991
lichfield ,staffordshire
Thinking of a f/g roof
does anyone know what the weight saving is over standard, apparently you have to leave a lip so i can't see it being worthwhile?
opinions?
JT
Member #: 637
Hertfordshire
I'm sure you could find this in a old search.
I personally don't think it would be worthwhile. You'd lose a fair bit of strength in the shell I'd imagine.
My build thread..
05bwardl
Member #: 9991
iv had a search but cant find the weight that would be removed, i will try and work it out from the volume of metal removed, just need the weight of the f/g panel
You would lose weight, and I'm sure it could be made stiff enough if bonded correctly.
What is the car being used for?
05bwardl
Member #: 9991
stiffness shouldnt be an issue as it has a multi point cage going in wich picks up front subby and rear beam, (its a race car for the road)
Its more a case of cost per KG savings and iv it would be better spent somewhere else.
Its up high so would be good to get some weight out i guess?
I would estimate 5kg with glue and everything else. Someone did weigh it not to long ago.
05bwardl
Member #: 9991
5KG saving or KG for the new panel and glue?
A race car for the road, ok. The reason I ask is that if you wanted to use the car for actual motorsport, a GRP roof would not be eligable for lots of things (hillclimbing for a start).
I don't know how much a GRP roof is, but it's probably not a bad £/kg ratio.
slater
Member #: 1291
Suffolk / Birmingham
I think you will find you loose a fair bit on a carbon roof. I seem to remember somone saying 8kg.?. I'm not sure how fg compares. One thing that may sway you however, the roof is exactly where you want to be loosing weight, high up in the car! 5kg lost up there is going to make much more difference than 5kg lost down low as far as handling goes at least.
05bwardl
Member #: 9991
just done some maths, assuming its 1mm sheet with a density of 7.85g/cm3
i guess the bit i would remove is about 1.2m long and 1m wide?
So a removal of 9.5kg of steel? (9.420kg)
alaskanow0
Member #: 8466
Mansfield
4.8kg saving on my arc angel opt 3 carbon roof inc. tiger seal
05bwardl
Member #: 9991
sounds like a decent saving!
i dont suppose anyone knows how much more a fg roof is over a cf?
1kg at a guess?
1380rich
Member #: 9766
Warwickshire
Both of my fg roofs distorted over time, my Curley carbon roofs been great for 5 years now.
Well worth going with a cf roof and the fit of the Curley roof is great compared to the other fg roofs from elsewhere
Avon 2010 class c 3rd
bit of chat on panel weights in this thread
http://www.turbominis.co.uk/forums/index.p...tid=303591&fr=0
Last time i fitted an fg roof skin you lose no stiffness in the shell, as it's all around the roof seam which is still left in place. Still had a half cage though but unless you have one that ties to the shell on the pillars it makes no difference to shell stiffness, it's more of a safety margin if for some reason you end up on the roof, composites aren't going to hold up like steel does scraping across the ground.
05bwardl
Member #: 9991
cheers guys, insightful as ever looks like im getting a f/g roof then !
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
mind blown on how heaven sheet metal is 9kg or so for a 1 meter square makes door skins/ doors a good option also?
D4VE
Member #: 10749
lowestoft suffolk
I too thought 'bollox' when someone told me how heavy a metal door skin was... but i brought ali skins chopped off the steel skin n they were right!!
Nothing gets past Dave lol
05bwardl
Member #: 9991
Already got the f/g doors and plastic windows, just need the other windows .
Will have f/g front inc a panel , f/g boot and roof
Got to be getting on for 50kg out the shell
Will just about offset the cage !
T45 cage?
05bwardl
Member #: 9991
Probably go cds as it only £630 Rather than 1300+ I think it's about a 10 kg difference between the 2 the t45 multipoint is about39kg
Has anyone got a weight for a multipoint weld in safety decides cage as its probaby what is going in
D4VE
Member #: 10749
lowestoft suffolk
Shoulda just gone full f/g silhouette! ;-p
05bwardl
Member #: 9991
I have a space frame in the garage but gave decided on a new shell
05bwardl
Member #: 9991
duds100
Member #: 8837
Warwickshire.
I've got a Curley Carbon roof same as Rich that we got on the same order (5 years ago). Still looks as good as new & I saved 8.7kg, notably from the highest point on the car.
Also, when the roof was cut off it enabled great access to weld the cage to the top of the A & B pillars before bonding the roof on +rigidity WIN
1976 Mini 1000 FWD R1 - 13.2@104
1975 Mini 850
INSTAGRAM @duds100
youtube.com/miniduds
