Page: |
Home > Beginners Tech > Realistic rpm max and final drive | |||||||
![]() 31 Posts Member #: 1961 Member Wellington New Zealand |
26th Apr, 2017 at 09:48:14am
Have a Austin 1300gt engine running forged pistons 7.9 cr , standard gt rods / flywheel , 255 piper turbo cam , 13 stud head , double valve springs, s rockers. Gearbox internals are St ratio backlight, and I have an abt diff.
3590 Posts Member #: 655 Post Whore Northern Ireland |
26th Apr, 2017 at 10:38:40am
rpm ability will be down to crank, rods, pistons, camshaft etc etc.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
26th Apr, 2017 at 01:30:19pm
Mine is there and ive only hit it once, but its all down to individual engine imo On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! ![]() 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
27th Apr, 2017 at 08:34:13am
Thanks, for the replies. Main use will be motorsport events and no doubt most of its life spent below 100 mph. Would like to enter a targa event where some of the roads would see max rpm in top on quite a few sections. Thinking 110 115 would be limit of power verse air drag if taken out to 7000 rpm. Turbo sweet spot looks to be 2200 to 5000 ish. |
4306 Posts Member #: 1321 Post Whore Wiltshire |
27th Apr, 2017 at 08:49:38am
I would be tempted to fit an ultralight flywheel and backplate to loose some weight off the end of the crank. Sounds like with the power tailing off 7k will be about the limit. On 7th Oct, 2010 5haneJ said:
Page: |
