Home > Wanted > Verto clutch covers
JT
Member #: 637
Hertfordshire
Hi
My double grey diaphragm is slipping at 15psi, so I'm going to convert to an rts setup.
Has anyone got a turbo clutch cover they'd sell? Obviously I need two.
Or maybe a 1275 and a turbo one would do?
Thanks,
Josh
My build thread..
We used 2 used 998 springs on the metro van running close to 30 psi with no problems.
yep as per the RTS thread, 2 1275's shopld be more than up to the job, just use what you can find.
worst case, you could always pop a thicker spring on later.
I have a spreadsheet of RTS guress work, PM me your email address and I'll send it over.
jonny f
Member #: 9894
Dorking
I'm using a 998 and a 1275. I found the 1275 and turbo a bit on the heavy side.
JT
Member #: 637
Hertfordshire
Have you got the turbo one for sale jonny?
I've found one with a dark blue dot. And there's another I have with no mark on it.
I'm going to get a minispares lightweight flywheel or med one.
My build thread..
jonny f
Member #: 9894
Dorking
No sorry
