Page: |
Home > Non-Mini Discussion > The mrs' high pitch whinning... in 5th gear ;-P | |||||||
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
16th Apr, 2017 at 08:42:30pm
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
16th Apr, 2017 at 09:20:20pm
Errr what car??
6729 Posts Member #: 618 Post Whore Glasgow |
17th Apr, 2017 at 06:44:08am
Sounds like a sticky jangle sprocket to me |
9317 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
17th Apr, 2017 at 08:48:41am
If it's only doing when she is in the car kick her out and enjoy the peace |
17th Apr, 2017 at 08:52:31am
Hahaha im such an idiot!! Sorry guys! Its a 2001 vw polo 6n2 1.0 mpi On 24th Oct, 2015 jonny f said:
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
17th Apr, 2017 at 09:17:07am
I thought you were on about Vicky Butler-Henderson. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
17th Apr, 2017 at 09:43:32am
German and whining.... I'm sure there's a brexit joke in there somewhere...
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
17th Apr, 2017 at 10:54:07am
check gear oil level, running in 5th for a while what little there is is probably gettting hot or emulsified. at a guess. turbo 16v k-series 11.9@118.9 :)
17th Apr, 2017 at 10:38:09pm
Ay andy? (Edit- just got that joke)
18th Apr, 2017 at 05:50:38am
You'll have to find the info out, usually the box oil never gets changed on VW's as the outputs are flanged and so oil never gets lost when swapping a driveshaft etc. So I would get it warm, drain what is left, refill with new.
971 Posts Member #: 3228 Post Whore North of the Netherlands |
19th Apr, 2017 at 10:01:56am
Advice I got some time ago; before draining gearbox oil check if fill plug will undo. On some gearboxes these can be quite stuck apparently. Dazed and Confused.... |
19th Apr, 2017 at 11:23:17am
haha yea be quite the annoyance if you drop the oil and the fill plug is stuck real good
19th Apr, 2017 at 07:14:34pm
Well... the oil for this is hella expensive compared to most, after lots of different instructions on the net i found the inlet in the awkward place that is! Went round a mates to use his 17mm hex head socket that you need for it.. he said lets do it here.. stuck my finger in the hole n couldnt feel nowt.. it took bout half a litre til full i say about because some did get poored into my beard!
20th Apr, 2017 at 09:00:19am
result |
20th Apr, 2017 at 09:39:12am
20th Apr, 2017 at 10:45:39am
Well you have done at best half a job.
20th Apr, 2017 at 12:17:29pm
Cheers guys, fully understand tom and will get done when i can.. tbh i just wanted to see if the noise would disapear before spending £50/60 on enough oil to change it completely On 24th Oct, 2015 jonny f said:
20th Apr, 2017 at 02:13:36pm
I'm sure you can find box oil for less than that? Check ebay out for the correct grade. A quick google suggests 75W90 @ £20.65 for 3L
Edited by Tom Fenton on 20th Apr, 2017.
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
20th Apr, 2017 at 04:50:52pm
hmmm oily box 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
Page: |
